Question about Home
Sanibest won't grind or drain water I flush and it
4 Suggested Answers
  • 17 Answers
SOURCE: Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
Posted on Jul 07, 2009
  • 37 Answers
SOURCE: seems to be leakage out of the hole on the top of
If hole has a carbon filter in it then this is the air vent. If water is leaking from here then a known fault so contact nearest sani engineer (2yr warranty). Check water is not dripping down from above first!
Posted on Feb 26, 2010
  • 33 Answers
SOURCE: My turboflush macerator does not take all the
indicates that the unit may need cleaning /descaling. alternatively the 22mm pipework (outlet) may be partially blocked
Posted on May 10, 2010
Fisher Paykel GWL15 won't drain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Aug 17, 2012 | Fisher Paykel EcoSmart GWL15
Top loader Neptune machine won't drain water and
Apr 06, 2012 | Maytag Washing Machines
Condensation building up under crizper drawers icing up somewhat and overflowing out onto floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
oldtech2332_6.jpg-->-->
Aug 16, 2011 | Frigidaire FRT17B3A Top Freezer...
Where is the drainedge for the radioter
For a 2001 Buick Regal GS 3.8 Liter, Supercharged engine:
First, let engine cool some. Second, locate small drainage hole at the bottom left/drivers side, of the radiator. From the bottom of this small drain hole, go straight back toward rear of radiator, then up about 1 1/2 to 2 inches up. (Have a drain pan or pail handy, to catch the old antifreeze.) You'll find a dark colored drain nut. Use a larger, correct sized socket ratchet wrench & loosen this fitting a turn or so, counter clockwise. Old antifreeze will begin to come out the bottom drain hole. The more you loosen the fitting, the faster the fluid flow out. I wouldn't remove the drain plug completely, or you'll loose control of the draining flow rate.
I just changed my anti-freeze just last week. I also changed the 2 large radiator hoses & smaller 2' overflow hose at the same time, as long as I was doing the job. They had never been changed before. I also used new hose clamps & a small packet of "radiator hose grease", from Autozone.. I drove the car up onto front car ramps to make it easier. I used safety jack stands for extra care. " You-Tube" shows some, "how to videos", that are helpful.
The old hose clamps are difficult to get to. (You'll need a few tools, some time & patience.) To get to the upper clamp, near the right/passenger side of the of the car, near the battery, I removed the outer serpentine belt & tension pully. I then removed the factory installed spring tension clamp, with the help of an adjustable battery pliers. The bottom of this hose wasn't too bad to get to. On the left/drivers side of car, remove black air intake box to access upper clamp. Remove the black metal brace bar, the will allow access to the air intake black box.
I also changed the small overflow 2 foot long hose & 2 clamps, that goes from radiator cap area, back to the overflow white plastic tank, close to passenger firewall. I removed the overflow tank to clean it out as well. I drained the fluid & changed the 3 hoses & clamps. I then placed all removed parts back where they belong, including white plastic overflow tank, tension pully & outer serpentine belt, air intake black box & metal diagonal brace, contacting air intake box. I flushed the system with some Prestone Radiator Cleaner & clean water. Start car & get up to temp., then run for about 10 minutes. Let cool, then drain again. I flushed my car at least 2-3 times after this, until the drain water ran clear.
The best price on a 5 year/150,000 mile anti freeze, came from Wal-Mart. I then mixed about 50/50 with Distilled water, as suggested on the bottle. All went well & no leaks! I took my time and did a thorough job. Good luck!
Jan 16, 2011 | 2001 Buick Regal
My sanibest is just humming. I am assuming that the motor is clogged with something disgusting. I have a toilet, sink, and bathtub going into the sanibest. Unit stopped working as soon as tub was draining...
Bail out as much as you can through the toilet bowl. Unfortunately this is a messy job regardless and you will still need newspaper on hand.
If you lower the water level below that of the rubber gasket connecting it to the toilet though, you will be able to undo the jubilee clip holding this and slide the unit away from the toilet, hopefully without spilling much waste water.
If you can dislodge the blockage from this angle, great. If not, you might also have to take the lid off by depressing the plastic clips on each side and accessing the chamber from the top.
Oct 17, 2010 | Saniflo Sanibest macerator with multiple...
The water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Sep 26, 2009 | GE Profile Arctica Stainless Steel Top...
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Home Logo
57 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
