Question about Coffee Makers & Espresso Machines
Delonghi ec 150 leaks from bottom
Hi, my delonghi EC 150 leaks water from the bottom. I think it comes from the water tank but i'm really not sure of this. I really don't want to buy another machine (4 years old max) and want to repair it. Any idea from where to begin the search ? Thanks
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Posted on May 10, 2009
espressonist
  • 1711 Answers
SOURCE: Our 7 year old Saeco Magic Delux has started to
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Posted on Feb 25, 2010
  • 7 Answers
SOURCE: My deLonghi Magnifica EAM3200 coffee maker is
I have the same problem, it leaks all over the place and makes a mess inside. Initially it just seemed to leak steam but it got worse and worse until now it leaks water badly. I took it apart and it appears to be a small orange silicone seal that's bad. The seal is located on the plunger that compacts the grinds and then forces water through to make the coffee. I took mine completely apart but I think by using a stubby Phillips you could remove the small black cap and replace the O ring easily. The O ring on mine that is torn is about .35" OD and about .15" ID.
To check if this is the problem on yours; turn off the machine and remove the main filter unit by pressing the two red "press to remove clips" and pulling the unit out. It will not come out with the machine powered on. Now look up into the top right hand corner and you''ll see the plunger and heater unit angled towards the center of the machine. There are two small stainless countersunk Phillips screws. Remove these and you should be able to see the small orange silicone O ring in question. Might be a good idea to replace the large one as well as it now pops right off and you can certainly clean around it now, something I was never able to do before. My small orange silicone O ring was torn into two pieces and I'll replace it tomorrow and see if it helps.
Posted on Jun 14, 2010
  • 37 Answers
SOURCE: delonghi coffe maker leaks water from bottom
The problem is that the heated water is leaking out of the drip chamber. This is caused by the fact that they were to cheap to use stainless steel screws that hold the chamber top to the bottom. The screws have rusted and the hot water can escape the drip area and runs down next to a plastic tube that delivers the hot water to the top of the coffee maker from the heating element. To repair you have to remove two screws that are on the underside of the hot water drip area above the coffee filter. Then there are 3 tabs that have to be released and separate the cover that has the strength control from its base. When you pop off this cover, you will see the remains of 4 screws that are badly rusted. I used a small ez-out and drill to remove the remains. Be very careful to not drill the pilot hole through the top. I got lucky and was able to remove the screws and replaced them with stainless steel. An alternate method would be to use a food grade 100% silicon adhesive and glue the to back together. This method may leak in the future, so try to get the old screws out first.
I would recommend a MR coffee $30 to $50 models, on sale, for coffee before I would ever buy this European designed junk. I took this thing apart and just shook my head and said that you can tell things that aren
Posted on Mar 14, 2011
Delonghi EC 820B leak from the bottom edge of the Boiler outlet/ Infusion assembly.
the hose has become clogged up with deposits and split.. you can try to take apart and repair yourself or look up your local shop for repair
Jun 10, 2016 | DeLonghi EC820.B Black Pump Espresso...
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Hi I'm bill I just to want to ask something regarding about my delonghi ariagel ag75 7,500 BTU/h.its a portable conditioner with 3 modes.And ive been using this for almost a year now.And wasn't...
Hi Bill, I also have a Delonghi portable air-con, so I hope I can help. Is the machine working ok apart from the leak? Does it have a built in waste water tank as does mine? If so, take a look at where the tank is placed to empty the machine, it is possible that the pipe leading to it from the machine is out of position and instead of filling the tank with water, it is dripping on the floor instead. If you remove the water tank, the machine will not run on air-con, but if you have a look at where the tank fits in (you will need a torch) you should be able to see where the water is coming from.
These machines do create a lot of waste water, that is normal, but it should end up in the water tank, not on the floor, so you need to find out why it is not reaching the tank.
As to your problem with the manual, I have found these links for, Delonghi so that you can contact them directly and explain that you need a replacement. As I don't know what country you are in, I have put a few for you to try, they should forward the query, or refer you on.Hopefully, they will either email you with a copy, or they might post a replacement. Good luck!
http://www.delonghi.com/uk_en/agency/
http://www.delonghi.com/us_en/agency/
http://www.delonghi.com/au_en/agency/
Aug 21, 2011 | DeLonghi Heating & Cooling
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Air tank leaks along the weld
NO,NOT FOR MINE,REMOVE TANK FILL WITH WATER AND TAKE TO A WELDING SHOP.THATIS THE BEST AND SAFEST WAY
Jul 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
Coffee Makers & Espresso Machines Logo
101 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
