Question about Garden
Husqvarna l021h48d will not go into gear
My husqvarna yta 18542 will go forward but not reverse
Linkage to the gear box reqires adjustment, look on top of the gear box and watch the movment from forward to neutral, then watch the movment from neutral to reverse thet should have approxamatly the same amount of movement, if not adjust the link rod.
Aug 17, 2017 | Husqvarna Garden
How does one take the metal worm gear off the crankshaft for a Husqvarna 142e Chainsaw?
What you need is the Husqvarna 530031136 oil pump gear puller.
Feb 08, 2015 | Husqvarna Garden
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
My husqvarna 172 cutting gear will not work checked the cable with spring and it was connected but seemed slack
hello, don't understand what you mean by cutting gear not working,let me know,
Feb 19, 2012 | Husqvarna Garden
Husqvarna YTH180 rider, wont go into gear.
Make sure that the tranny has fluid in it. Then try rocking the mower back and forth until you rock the tranny loose.
Best regards, --W/D--
Aug 08, 2009 | Husqvarna Garden
Bar oiler problem, replacing plunger did not fix the problem
the worm gear is on the plunger.the gear that is on the crank shaft,if i remember is a nylon gear.some times they look prefectly fine but they slip on the crank shaft and do not trun the worm gear fast enough to oil. here is a parts breakdown for that saw......http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401904.pdf look on page four 4.......i hope this helps,let me know........................
May 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
