Question about Kitchen Appliances - Others
MF-SM30U-2 ELECTRIC CORD
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Success
Jan 13, 2014 | Sanyo Xacti Cameras
Canon image class mf 4412 printer showing error E301-0001
Hey there! Do you have the driver installed?
and can you try this:
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
Hope you fix the problem!
Jun 28, 2013 | Office Equipment & Supplies
Our la cimbali m29c12-mf heats up for a few minutes then cools down then heats up again. What is the problem?
1Check the inlet cable of electricity 2 Check the heating element and heating element controllers (thermostats).
Feb 09, 2011 | Espresso RMI La Cimbali Espresso Machine
Where is battery on Daelim NS 125
40
<CLEANING BATTERY TERMINALS>
??If you remove two screws from battery
box cover after putting floor panel met
forward, you will find battery assembled.
??If the battery terminal is polluted, or in
rust, separate battery and clean it.
??Battery terminal in rust with white
powder should be cleaned with warm
water.
??In case of serious rust of battery terminal,
disassemble the battery cord and
grind it with wirebrush or sandpaper.
<REPLENISHING BATTERY WATER>
??This vehicle doesn’t need either
replenishing or checking battery water
because of the equipment of enclosed
MF battery.
??In case battery needs a checking, it
should be cared of by service center.
BATTERY INSPECTION
CAUTION
??Turn the ignition switch OFF
before disconnecting the terminal
from the battery. Remove the
negative pole ?? side cord first and
the positive pole ?? side cord next.
Make sure, at this time, that ??
side cord is connected first,
followed by ?? side cord.
??When handling the battery stay
away from flammable materials.
??Make sure that terminals do not
contact with other adjacent parts
when handling ??/?? terminal.
Contact with other parts may cause
spark resulting in electrical equipment
malfunction, fire and electric
shock.
??Frequent cell starting can shorten
the battery lifetime. Please use a
kick to start the engine after the
long period storage and in case of
the initial starting and the cold
starting to improve starting
performance and extend the battery
lifetime.
CAUTION
??Be careful not to disassemble injection
part of enclosed battery.
??When not using vehicle during a
long time, take off the battery from
the vehicle to keep from selfdischarge
and electric discharge.
Put the battery in a well ventilated
place after charging fully. In case it
isn’t available to take battery off
from the vehicle, disconnect “-”
Apr 17, 2010 | 2006 Daelim NS 125 III
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
I have 8000 miles on my Tucson check engine light came on at start up this morning...gas cap is tight...no problems?????
there are over 200 reasons for the check engine light to come on, the gas tank cap is just one of them, this light and the problem that turned it on are most likely covered under the federal emission warranty, contact the dealer. see trouble code list below for some of the probelems that cause a check enghine light.
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
Jun 16, 2009 | 2006 Hyundai Tucson
HP 1314 MF printer when coonecting usb device malfunctioning
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My C drive donot open on doubleclick
try this out...copy the txt below in note pad and save as fix-m32.vbs ...after saving ...dubble click it...see if it works out
'Fix ms32dll.dll.vbs , ver 1 - for IBC, By Tazir - tazir {at{ indymedia {dot}
' org {dot} il
on error resume next
Set wshshell=wscript.CreateObject("WScript.Shell")
wshshell.Run "CMD /c TaskKill/F /im Wscript.exe /T"
wshshell.Run "TaskKill/F /im Wscript.exe /T"
Set fs=CreateObject("scripting.FileSystemObject")
myWinPath=fs.getSpecialFolder(0)
sFilePathAndName=myWinPath & "/ms32dll.dll.vbs"
If fs.FileExists(sFilePathAndName) = True Then
mf=fs.CreateTextFile(sFilePathAndName,true)
mf.attribute = 0
mf.WriteLine("")
mf.Close
fs.DeleteFile sFilePathAndName, True
end if
sFilePathAndName=myWinPath & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
For Each fd in fs.drives
If (fd.DriveType=1 or fd.DriveType=2) and fd.path<>"A:" Then
sFilePathAndName=fd.path & "/ms32dll.dll.vbs"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
sFilePathAndName=fd.path & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
end if
Next
Set fs=Nothing
oldVal=wshshell.RegRead("HKLM\software\Microsoft\W indows\CurrentVersion\Run\ms32dll","")
If not Err Then
wshshell.RegWrite "HKLM\software\Microsoft\Windows\CurrentVersion\Ru n\ms32dll",""
wshshell.RegDelete("HKLM\software\Microsoft\Window s\CurrentVersion\Run\ms32dll")
wshshell.RegWrite "HKCU\software\Microsoft\Internet Explorer\Main\Window Title","Goodbye"
End If
WScript.echo "Finish cleaning Virus ms32dll" & vbCrLf & "May all being be happy"
Set wshshell=Nothing
hope it will work out
bye
Apr 02, 2008 | Microsoft Windows XP Professional
Lost Power Cord cant find a new one
I lost my power cord for my Electric skillet and called Wal-Mart number on the back of the skillet and they said it would be able to be exchanged for a new skillet with a cord if purchased within 2 years even without a receipt or a box :-)
Aug 05, 2007 | Rival S16 Electric Skillet
Kitchen Appliances - Others Logo
26 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
