Question about Apple iPod touch
Locked what do i do if i got my self locked out of my iPod touch
    New Friend:
  • 3 Answers
Here's a video iliana suggested as a solution to your problem from YouTube:
PASSWORD LOCKED iPod Touch - How to RESTORE a Disabled iPod with a lost Pass Code Unlock Video
Posted on May 01, 2013
I can't unlock my ipod touch
Connect it to itunes, with that you can unlock it, just sync.
Mar 13, 2014 | Apple iPod touch
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
How do i unlock my ipod touch
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
Ipod 4 is going haywire
The Best thing to do is restore it bye putting the cord in your laptop and press restore at the bottom
Dec 02, 2012 | Apple iPod touch 8 GB 4th Generation White
I LOCKED MY IPOD TOUCH BUT I FORGOT MY PASSWORD. COULD YOU HELP ME UNLOCK IT?
If your iPod touch is password locked, the only way to get past it is to force the unit into restore mode by doing the following: 1. Plug the iPod touch in to your computer. 2. Hold the sleep/wake button and the menu button down at the same time. Keep them both pressed until you see the 'restore' screen (an iPod cable and an iTunes disc symbol) on the iPod touch. Release the buttons. 3. iTunes should now display the iPod touch, along with a message that the iPod touch is in recovery mode. Click the RESTORE button in iTunes to restore the iPod touch. Please note that doing this will erase the contents of the iPod touch -- that's how the system is designed to work: a passcode lock is meant to protect the data on the iPod.
Jun 01, 2010 | Apple iPod touch
Ok i locked my ipod and cant remember the combo and i cant find "my computer"in which every1 says to go to to unlock it i need help!!!!!
Jun 03, 2009 | Apple iPod touch
Sync locks up PC
Try restoring or resetting the iPod.
Apr 21, 2009 | Apple iPod touch
Netgear 834
changed wep to wpa.ipod works great
regards
Jan 05, 2008 | NetGear DG834G Router
Apple iPod touch Logo
238 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
