Question about Freezers
Liebherr GS 5203
Not reaching required temperature, warning light on
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
Aug 11, 2016 | Electrolux Freezers
Why does ice cube maker have a yellow warning light on it and it's not making ice?
It is telling you something is wrong! Check your manual for what the warning light signifies and take appropriate action. Look under troubleshooting. Also check out support at web site for manufacturer.
Feb 12, 2016 | Liebherr Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Liebherr comfort no frost not working
Have you tried cleaning the condenser coil. They are located at the bottom of the unit and have a fan blowing them. As clean as possible is very important to operation. Let us know about this step. Roger
Apr 18, 2014 | Liebherr Freezers
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
In my freezer, there is a blinking red light next to the icemaker on-off switch. What is it and why is it blinking?
It might be blinking because it hasn't been able to reach the required temperature or the temperature you have set. Probably leaving it close for one or two days, the light will go off, if not, you might consider changing the plastic isolation of the door, you know, the plastic thing that you see goes around the freezer door, best luck.
Jul 26, 2012 | Freezers
Freezers Logo
55 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
