Question about Health & Beauty
Windmere prelude missing charging wire/cable model 9301
My 1990 prelude will not charge the batt while driving and batt light is on
you will need a new alternator. battery light means there is no charge in the electrical system. always first check the earths and wires before changing the alternator as a faulty earth can also be the main problem.
Oct 10, 2013 | 1989 Honda Prelude
How to charge massager without charger
You cannot charge a battery without a charger. Why not just buy an adaptor that will do the job?
May 02, 2013 | Computers & Internet
Windmere fans parts
It's not worth to buy replacement parts, when portable fans costs from 15 to 20$ :/ take a look and decide Finally charging for our multi device world
Jun 25, 2012 | Dryers
New altanator and battery car is still not charging my battery 91 honda prelude
there is a cable mounted on the altanator farsten by a 12mm nut if that is broken or not hooked up
unit will not charge. use a tester to check for continuety or chech conection on battery harness
Jul 19, 2011 | 1991 Honda Prelude
My 98 prelude wont sttay on.. i replaced the alternator, batterym spark plugs and wires.... everytyme i get a jump it comes on and as soon as i take em off the car shuts off
Well, you seem to have replaced parts that I would have changed in the course of trying to solve a starting/charging problem.
And a tune up problem.
I would recheck the connections at the battery and clean with a wire brush if necessary.
However, the alternator, if working correctly, should keep the car running after you start it with the jumper cables. There's something wrong there, I think.
Jul 30, 2010 | 1998 Honda Prelude
1992 prelude si - battery/alternator prob?
if you can charge the battery and drive it for a while then sounds like the altenator has failed and is not re-charging the battery, good way to test is to charge the battery, start the car and turn the light on, if everything is dimm or the motor dies there is little to no charge voltage, and will require altenator work
Jul 01, 2009 | 1992 Honda Prelude
Clutch
it is a hydraulic clutch system, especially on the 89 prelude. I have one the exact year model, and i had a hole in the slave cylinder hose going to the transaxle from the slave cylinder.
To refill the reservior, use DOT 3 brake fluid. The reservoir is located just to the left of the brake fluid reservoir underneath the hood on the driver's side firewall. you can't miss it.
Sep 09, 2008 | 1989 Honda Prelude
Health & Beauty Logo
75 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
