Refrigerators Logo
Anonymous Posted on Apr 27, 2013
Flap ice dispenser door
The ice dispenser works well with the switch is activated. However, it will randomly 'spit' out ice onto the floor when not needed. Assistance appreciated.
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 25, 2008
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
BarryisEager
  • Posted on May 05, 2008
SOURCE: Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
A
Anonymous
  • Posted on Aug 02, 2008
SOURCE: Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Anonymous
  • 3361 Answers
  • Posted on Mar 23, 2009
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Anonymous
  • 8619 Answers
  • Posted on Mar 31, 2009
SOURCE: KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
How do I remove ice dispenser from samsung rfg297aars
here ya go.
https://www.ifixit.com/Guide/Samsung+French+Door+FRG297HDRS-XAA+Ice-Water+Dispenser+Microswitch+Replacement/66568
Grab the black dispenser port with a strong hand and hold the door from opening with another, or your shoulder. Firmly pull the assembly away from the door. It will take a quick, firm pull to do the deed. The assembly is held in place by several plastic lock tabs. These will give way without breaking.
pushing the fridge back will be easier than pulling it around.
Best of luck and hope this helps you.
2answers
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
3helpful
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
3helpful
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
I have LG side-by-side fridge freezer (GRL197NIS) with a Premium ez digital ice maker. When the ice cube or crushed ice is in operation the ice gets backed up inside the dispenser/door as the 'spring...
The answers gave me the confidence to have a look and on mine the arm had come out of the catch the other end from the solenoid.I just had to push it back in. So grateful thank you very much. It's not been working for about 18 months and I couldn't afford to pay someone for something that was just a luxury. A BIG THANK YOU!!
Ice dispensor in the door will not dispense ice
do you here anything at all happening when you hit the switch... if you not then most likely got a bad door switch or handle is broke at the area where it makes contact with the door micro switch...if you are hearing noise when activating the door switch you are good at the door... with the door opened hold down the actually freezer door switch and look in your ice maker while someone activates the ice dispenser switch. makes sure the augur motor is turning and if it is then make sure it is turning the ice bucket auger screw fairly simple process to go through... the operation is as follows the dispenser handle makes contact with a microswitch in the door and sends power to the auger motor telling it to turn.. once the auger motor starts to turn then it makes contact with the screw in the bucket and turns the screw in bucket forcing ice to front of dispenser and the dispenser has a flap that works both off of power sometimes or just by force of hand others... make sure it is opening and chute down and out door is opened. hope this helps good luck
2helpful
When i place my cup into the ice dispenser it won't shut off. just keeps spitting out ice for minutes.
Sounds like the actuator switch has moisture in it .
1 ) remove the top hinge cover from the freezer door and disconnect the plug there . This removes power to the door .
2 ) Use a small screwdriver under the dispensor control panel , and
pry outward , to remove the panel .
3) Disconnect the 3 plugs to the panel .
4) Remove the 4 screws holding the white dispensor cover on , and
remove the cover .
5) Push in on the cover arm , and you will see the switch which is
activated by the arm . Replace this switch .
6) With this cover off , look in the dispensor area , and make sure the
door flap snaps closed completely . If not , then this is where the
moisture is comming from , and the solenoid at the top right , is
probably rusted , and needs to be replaced .
re-installation is in reverse .
2answers
Ice maker will only dispense crushed ice
You may have a broken solenoid inside the motor assembly.  The solenoid controls the arm for cubed or crushed ice.  The only way to tell is remove the ice dispenser motor assembly and look at the solenoid.  If the solenoid is broken, replace it and everything should be ok.
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
