This problem should be removed because:
Problem with Car Video Players
Sound problems with installing radio in 2001 tahoe
I have installed a new radio in my 2001 tahoe with the wiring adapter. The radio powers but does not produce any sound. I noticed a wiring harness that plugged into the factory radio but it does not connect to the aftermarket. There is o problem with the radio, I checked it out in my 2000 chevy 1500 and it works fine with the same harness. Please any help will be appreciated!!!!
Thanks
Solutions (2)
Best Solution
There is 2 harness the one that you are usin wich is the main harness in the second one that normally is conected to power up tha casette deck,there it should be a pink wire conect this wire together with the red one located on the main harness,if you have any problem call me 830 488 2078 im in texas ask for Tony
I have the same problem I have 2001 tahoe took manufactured cd player off put a Kenwood cd player but I don't have audeo coming out some times it works but as soon as I turn tahoe off and turn it right back no audeo comes out got hardness wire connection but the only one from cassette wire are not connect and the hardness wire I bought dissent have another connection pls help going crazy here
I am trying to replace my factory head unit in a
I am trying to replace my factory head unit in a 2000 Lexus Lx470 and having no luck finding a wire harness to adapt an aftermarket deck to...
how to install a flip down dvd player in a 2001
how to install a flip down dvd player in a 2001 chevy venture minivan
I need Power plug harness re-placement where can i
I need Power plug harness re-placement where can i buy it
why do my rear door speakers do not work after
why do my rear door speakers do not work after aftermarket radio was installed in my 1996 chevy tahoe
Add Your Solution
Fix-O-Meter
1,065
1,065 people viewed this problem
- 3 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Car Video Player Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
