Question about Dometic RM2620R Refrigerator Classic
Door panel install rm2620... - Dometic RM2620R Refrigerator Classic
Ammonia smell
leak in cooling unit replace
Apr 04, 2014 | Dometic RM2620 Refrigerator
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
I cannot get power to my RM2620 refrigerator? Can you assist?
I would cheak the relay on the compressor it may need changing remove and shake to see if it is gone it will rattle alot if it is burned out.
Nov 27, 2010 | Dometic RM2620 Refrigerator
How do you take the door off a dometic refrig.?
There is a hinge on top that is covered with a small cap,remove the cap and the 3 screws and just lift the door off the bottom hinge.
Aug 18, 2010 | Dometic RM2620 Refrigerator
Door handle light shock when opened . Disappear when unplegged and replugged again with opposite terminal
un plug the fridge prior to opening the door grab desired food option and close the door and then plug the fridge back or stop bein a ***** if its a small shock man up
Apr 03, 2010 | Dometic RM2620 Refrigerator
Dometic rm2620 rv refrigerator
No you need 12vdc for the control board. If you have a convertor 110ac to 12vdc this will work for your supply instead of the battery.
Aug 29, 2008 | Refrigerators
Dometic RM2620R Refrigerator Classic Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
