Question about Watches
Seiko qxm130brh hourly chime will not work
Hi, the buttons B & C are jammed on my Seiko 7T92 wrist watch. Is there a lubricant or substance I can use without effecting the watch to free these buttons?
With Seiko, the best thing is to send it to Seiko for service. They will clean it and replace all the gaskets on the buttons, and pressure test it.
If you want to try yourself. It is waterproof, yes? Soak for a couple of hours in warm soapy water. Lift out, dry, and try the buttons. If they are now free, spray with Jigaloo, which is a dry silicone spray and work into the buttons.
Dec 18, 2016 | Seiko Watches
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
I have a seiko chonograph couturo alarm. 100m
Many of the Seiko Chronographs have the same setting options (mine is the lightweight "Titanium Sports").
First off, the alarm dial must show the same time as the actual main dial. If not you must adjust this first.
Pull the knob at number 4 position on the watch face out, until you feel two distinct notches/clicks (around 0.5mm travel) and the alarm will make a shrill buzzing for about 1 second.
Now turn the #4 knob to move the small alarm dial at the #6, to be the same as the actual time displayed on the main face, and press the #4 knob fully back in. This sets the alarm and the main time to the same ....er....time. You do not need to do this again, unless you adjust for daylight saving times during summer/winter.
Now you can set the alarm chime point.
Pull the #4 knob out again, but just one click. You should hear one ping from the alarm. Now press the button at #8 position. It will move the small alarm hands by 1 minute intervals, and if you keep it held in, the dial spins around quickly. This allows you to adjust the time the alarm will chime.
When you've got the alarm time and it's chime point set, leave the #4 knob at one click out.
If you wish to switch the alarm off simply press the #4 knob back in, and the alarm dial will spin around to the same time as the main dial.To re-enable the alarm pull the #4 out one click again. It's quite simple once you get the hang of it.
Jan 01, 2010 | Seiko Coutura Chronograph Watch
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Resetting the 'day'
Your Seiko has two pulls,first pull for DAY / DATE,and the second pull for the hour and minute.Just do the first pull then wind it clockwise for DAY and the counter clockwise for DATE.Feel free to ask whatever the result...
Hope this may help;
Regards,
VOTIT
Sep 03, 2008 | Seiko 0512037FA Wrist Watch
Watches Logo
29 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
