Question about SanDisk Sansa e250 MP3 Player
Navigation ring not working
The navigation button is not working correctly, when you go to turn volume up, it turns it down, when you turn it down, it turns it down - when plugged into the computer, it froze on the SanDisk start-up screen. Tried 20 second reset - got it off the start-up screen but button still not working - defective?? Had it for about 2 months only!
  • 34 Answers
Unfortunately, it wlooks like its time to return the unit to sandisk
Posted on Aug 07, 2007
SOURCE:
How to turn volume down on my phone
Assuming it is not a smart phone
when in a call, toggle the navigation control down. (that's the square surrounding OK button)
Smart phone has 2 options
1) volume toggle button on the side of the phone
2) Software > Apps> Settings > Volume
Jun 08, 2018 | Cell Phones
My phone is on mute, cannot hear it ring when making a call and the person on the other end cannot hear me talk and visaversa how do I unmute my phone HELP!!!!
You may have accidentally turned the volume right down. Try calling someone and when they answer, toggle up the volume using the navigation button.
Apr 10, 2016 | Cell Phones
Navigon easy 40 no sound
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law.
The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it.
This happened to me and this was the fix, odd but true.
Also see if there is a turn by turn vol level in settings.
Hope it works for you.
Aug 12, 2012 | Navigon 40 Easy 4.3" Sat Nav With Western...
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
I need to know how to turn up the ringer volume on my motorola q
To increase the ring volume, please go through following steps.
Press Start -> Settings -> profiles. Then highlight the selected profile and press Menu -> Edit -> Ring Volume. Press the right navigation key to increase the volume.
Mar 09, 2011 | Motorola Mobility Moto Q
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
Nov 27, 2010 | Samsung SGH-D900 Cellular Phone
How do i turn up the volume on my nokia mobile phone
While in call,you can press the scroll navigation right button for increasing volume and scroll navigation left button for decreasing volume!
Nov 21, 2010 | T-Mobile Nokia 2610 Pay-As-You-Go Cell...
How do you turn the volume up on a Nokia 2600 cell phone.
Are you referring to the volume when you are under an call or the ringing volume..?
If it is under an call please press right side navigation button when you are in an call..
If you are referring to the ring volume , you can increase it in the tone setting options
Oct 23, 2010 | Nokia 2600
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
My vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
May 30, 2009 | Vtech 5867 Cordless Phone
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
