Question about HP Scanjet 4470c Flatbed Scanner
Software scanjet 4470c
Scans have become grainy
tom19511
  • 1601 Answers
SOURCE: Powering scanjet 4470c
Thats how its made.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bps02633&cc=us&lc=en&dlc=en&product=57956&dlc=en&lang=en
Posted on Nov 10, 2007
coolcat_12
  • 259 Answers
SOURCE: driver for scanjet 4470c on Vista
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Posted on Jan 26, 2009
  • 5 Answers
SOURCE: Disassembly of HP ScanJet 4470c.
You remove the panel that holds the control buttons by putting a small flat head screwdriver under the both outside edges (held by two small pins). Be carefull the ribbon cable does not unplug. After removing the two screws that are under the back hindge slots, the whole top pivots up and off of pins at the front. You feed the panel thru the hole left when you removed it. This frees up the top and the glass on both sides can be cleaned. Hold the glass up to a strong light to be sure it is clean before putting everything back in reverse order
Posted on Feb 19, 2009
  • 2841 Answers
SOURCE: HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Posted on Nov 10, 2009
SOURCE: The scan image becomes yellow
SCANNER G 2410 YELLOW BACKGROUND IN SCANNINNG.
Posted on Dec 17, 2009
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
Doesn't work
Scanjet 4470c does'nt work under Vista nor W 7 . No drivers available .
Here are a few hints :
1° hint :
Reboot .
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Otherwise , you will have to buy a new scanner , what you probably allready have .
Regards .
Jul 08, 2010 | HP Scanjet 4470c Flatbed Scanner
THe scanner works but the image is blank/no image
Try automatic settings or vary the brightness/contrast setting and scan. This should work. S. Mohan
Jun 13, 2009 | HP Scanjet 4470c Flatbed Scanner
4470c
If you can get the software on your computer, right click properties and check run in XP mode
Aug 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Scanning 35 mm slides
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 4470c Flatbed Scanner Logo
23 people viewed this question
Seeker5211
Seeker5211
