Question about Refrigerators
Crt216hlwo crosley refridgerator
Why is the freezer making loud noise
SOURCE: My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Posted on Dec 09, 2008
Sea Breeze
  • 4654 Answers
SOURCE: freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Posted on Jun 17, 2009
sawdust46694
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
  • 9 Answers
SOURCE: Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Posted on Aug 26, 2009
Testimonial: "It was very good advise."
SOURCE: My Kenmore side-by-side refridgerator is making a loud humming noise.
Sounds like your compressor is not starting due to a faulty "starter PTC" a.k.a. start relay. Or a faulty compressor. The buzzing noise you hear is the compressor trying to start. When it's windings overheat, an internal cut-off switch "clicks" off until it cool down.
Then the cycle repeats.
Posted on Feb 27, 2010
My crosley dryer (model# CED137SXQ0)made a loud ugly noise and stopped working i tried turning back on but it doesnt come on or make any noise.
check to see if the drive belt is broken. check out this video:
http://www.repairclinic.com/PartDetail/b171p8/Crosley-Dryer-Drive-Belt/341241/529597?modelNumber=CED137SXQ0&ss=a8b171d1287209&mr=1#repairHelpVideoTabs
Aug 04, 2015 | Crosley Dryers
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Has anything changed in the cooling? Can you locate the model number on your refrigerator.The noise is coming from under or inside the refrigerator or freezer? Let me know those few things and we will find out whats going on, Thank, Sea Breeze
http://servicepartstec.blogspot.com/
May 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Extra loud noise when spinning
most likely the main spin bearing at the top of the transmission just below the spin basket and seal
the bearings dontjust go out for nothing either,you will need to be replacing the tub kit seal also
not the easiest of repairs,may need special tools to remove the seal nut assembly...
Mar 17, 2009 | Crosley Washing Machines
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
