Question about Philips "32PFL3505D/F7 32-Inch LCD Hdtv, Black"
Color is not working. I only have a black and white picture
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: colors in back are working but getting a black and white picture
What model is your projection TV? Need the model number
Posted on Jan 17, 2008
SOURCE: picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Posted on Feb 22, 2011
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
The tv on;y shows a small pip window in color if it is a large picture the picture is in black and white how to fix?
Whatever input video signal you're using, PIP should be in color. What are you using out of your dvd for the second video input source, composite or component? Composite you should always have color, Component, if you have a bad red or blue, and just the green is working, you will get black and white. The green is the luminence signal.
Nov 23, 2011 | Televison & Video
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No color only black and white picture
one of your color tube has gone out on you.
Jan 25, 2009 | Hitachi 43F300 43" Rear Projection...
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Philips "32PFL3505D/F7 32-Inch LCD Hdtv, Black" Logo
15 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
