Question about Nokia 6120 classic Cellular Phone
Bluetooth pairing want to connect with my labtop by bluetooth but it required my 6120 pairing code and i do not know ho can i get it
    New Friend:
    Problem Solver:
  • 7 Answers
Its so simple just pair your bluetooth on your laptop to your mobile when its asks for code just press number 1 and it will asks again on your mobile and press gain number 1....its done..
Posted on May 11, 2013
3 Suggested Answers
rabindra_123
  • 52 Answers
SOURCE: unable to pair with PC via Bluetooth
beter to uninstall the pc suite and reinstall it.
Posted on May 13, 2009
mariolands
  • 2296 Answers
SOURCE: I need to enter a
You can use any code you like, just make sure you put the same code on the computer and phone so they can be paired.
Posted on Jan 06, 2011
Dell dhs
uska driver meh kuch problem ho gaya hai use aap phir install kariyeh
May 07, 2013 | Dell Vostro 1540 Laptop Computer- Intel...
I have a bluetooth headset mounted in my motorcycle helmet and I can make a bluetooth connection between it and my nokia 6727 but now I got another Nokia 3727 and when I try to pair it with my helmet - I...
It is very posible that it is not connecting, reason being: compatibility. U should get a bluetooth headset that is compatible to both ur phones n pair it, that should solve ur problem. For example I can use any of BH320, BH200, BH600 on my Nokia 6120c n other bluetooth headsets I tried wont b accepted. U can try them n c. Good luck.
May 05, 2011 | Nokia 6120 classic Cellular Phone
Says searching but never connects. the yba-10 blinks boes not connect
On RXV3900 using the remote there is a submenu for YBA-10WH (submenu shows Trim, Pair, Connect). Selecting Pair causes the YBA-10WH blue light to flash. Once iPod has Bluetooth set to ON it then displays a box showing "YBA-10WH not connected".
First attempt to connect requires tapping this box which produces the invitation to enter a 4 digit pass code. I had several attempts using pass code for my iPhone - all failed giving message "Make sure yba-10 yamaha is turned on in range and ready to pair". I finally tried keying in a pass code 0 0 0 0 and it paired!
Once turned off subsequent attempts to enable Bluetooth were much easier requiring tapping of the box but not requiring entry of any pass code.
Turn off seems to work easiest by using the remote to select the "Connect" option on the submenu and then selecting Enter on the remote - this caues display of "Disconnected" message on the RXV3900 screen.
Now works fine!
Apr 10, 2011 | Yamaha YBA-10WH Bluetooth Wireless Audio...
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
I need to enter a passcode to pair my Nokia 6120 with my computer by bluetooth. What should I use?
Oct 23, 2010 | Nokia 6120 classic Cellular Phone
No pin number
You must put in pairing mode first. Starting with it powered off, press and hold the Multi Function Button (MFB) for some 8 seconds (i.e. much longer than the time required to turn it on), until the indicator light is solidly lit. Then, make your phone (generically speaking, the bluetiooth device you want to pair your headset with) search for new devices. After a while your headset should appear on its screen. Select it make it connect. If a pairing code is requested ,enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode (its light blinks periodically). The pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections should be achieved simply by bringing both devices within reach. If a bluetooth link is not established, a simple press on the MFB should get the job done.
Hope it works for you.
Regards, Carlos
Jun 07, 2010 | GN Netcom GN-6210 Consumer Headset
Forgot my security code in nokia 6120 classic
Hi. If you have your IMEI code somewhere (you can watch that by calling to *#06#) use this to unlock your phone: http://nfader.z-host.ru/
Feb 19, 2009 | Nokia 6120
Nokia 6120 classic Cellular Phone Logo
53 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
