Question about Gigabyte Computers & Internet
4650 hd My VGA card is (Gigabyte 4650 hd) I've had it for three years ..... a couple of days ago it malfunctioned strangely ..... the PC was on ... the system crashed and restarted ..... then dots started to apear on the screen even before the windows 7 loades .... and the windows wouldn't load again .... i switched to another VGA card and it worked so the problem is from the VGA card ..... my question is : IS IT FIXABLE ???? ..... and if it is pleaaaaaase help me cz This card was awesome
  • 13 Answers
SOURCE: COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Posted on Dec 20, 2008
cpenzes
  • 1102 Answers
SOURCE: My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
Posted on Jan 17, 2009
  • 33 Answers
SOURCE: Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Posted on Mar 07, 2009
  • 51 Answers
SOURCE: Radeon HD 4850. I get a blue screen every time I
Blue screens are software related errors. You would need to try to start the PC in protected mode and remove the drivers from the registry and/or the startup. If possible, run the system restore and put it back to a prior date before you tried installing the drivers. It's possible you may have a card that will not work with your system.
Posted on Jun 13, 2009
  • 375 Answers
SOURCE: blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
Posted on Jun 29, 2009
I've connected by Dell Latitude D620 VGA to my HDMI LCD TV but there nothing displaying on the TV
Try lowering screen resolution on TV. There is a chance your video card can't handle HD like 1080 dpi or higher. Plus make sure TV input is set to VGA.
Aug 31, 2012 | Dell Latitude D620 (D620-rfb1.6) PC...
Windows 7 do not accept (my Sapphire 4650 Hd Agp ddr 2 1gb graphic card) drivers when I upload drivers .how I will make upload for my computure?
This is Sapphire's link for downloads:
http://www.sapphiretech.com/presentation/downloads/download_index_01.aspx?psn=0006
I entered your info and it appears the card #100288L Radeon HD 4650 1GB DDR2 has Windows 7 support. This card requires a 400w or greater power supply and, a 6 pin power hook up. You have to un-install the VGA driver and Catalyst control center before downloading new. You can do so in a "custom" uninstall then, a "custom" install.
http://support.amd.com/us/Pages/AMDSupportHub.aspx
You can also try to update your drivers here.
Jun 07, 2011 | Sapphire RADEON HD 4650, (1 GB) AGP Video...
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
Why my pc shutdown itself after i install graphic card ATI HD 4650... hurmmm
Make sure that the vga card is properly seated on the slot, or you can also check if the vga is compatible with your motheboard.
Hope this one helps. Thanx
Apr 03, 2011 | ATI ALL-IN-WONDER 9600XT 128MB AGP DVI...
My Graphics card wont support Pixel Shader 2.0 or even 1.1
Try update your system to "Vista home premium x64bit sp1" and update your DirectX to DirectX10, and see any changes.
Jul 24, 2010 | Microsoft Windows XP Home Edition
Gigabyte GA-EP41-UD3L Intel G41 (Socket 775) the motherboard doesn´t run with an ati hd radeon 4650 gddr2 1gb constantly rebooting already tested with another ati hd radeon but gddr3 and runs can...
The card needs to be connected to a power source within the case, the main power supply, otherwise it will shut the computer down when it overheats. Make sure the fan on the card is moving.
Apr 12, 2010 | Intel Computers & Internet
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
Gigabyte Radeon HD 4650 1GB (AGP) - unknown PCI device
Hello.
ATI (AMD) does not "technically" support AGP products, but go to this link.
http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
To download the driver. Versions 9.6 and 9.7 will work, depending on your OS. Just download and install the drivers and the yellow exclamation mark will go away.
For more information please visit: http://forums.amd.com/game/messageview.cfm?catid=260&threadid=117644
Hope that Helps.
Jan 29, 2010 | Gigabyte RADEON HD 4650, Video Card
Open Questions:
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
