Question about Briggs & Stratton Garden
Engine misfires and emits black smoke
I have a 148cc B&S engine on my mower. Model # is 09T602 5019 B1 manufactured in Aug 2011. It was losing power and eventually would not stay running. I cleaned the carb and it worked okay for a while, then the problem recurred. I have since emptied the tank and added fresh fuel. I have replaced the diaphragm and gasket under the carb. The plug is brand new and gapped to .030 inch. The air filter is clean. The oil level is correct. It has on of those ridiculously cheap plastic carbs on it that has no adjustments. The mower runs when started and continues to run, but misfires and emits black smoke like it is running rich. The longer it runs the worse it gets. Looking for a solution to this problem...perhaps replacing the carb? The thing is brand new and has only been used about 4 times...on the fritz most of the time. Used to think Briggs and Stratton was top of the line, but this engine is junk.
    Sergeant:
    Champion:
  • 278 Answers
You may still have to do a more thorough cleaning of the carb and all passages. I have not had these problems with mine yet to inform of proper technique and chemicals to use. To err on the side of caution. Remove the carb and clean in a ultrasonic cleaner with a water and simple green mix.
Posted on May 01, 2013
Testimonial: "Nothing on this mower seems to work. Thank you for your reply...unfortunately nothing has worked. "
  • 11 Answers
SOURCE: 4.5hp Brigss & Stratton engine.Engine runs rough.
Ok, check the air filter, it could be clogged. A clogged air filter won't allow a proper air-gas mixture. Then check the carb. make sure that it is clean, or if anything doesn't look right. You might have to get another carb. After that check the intake it could be clogged but this time a clogged intake means that there isn't enough fuel getting to the combustion chamer.
Posted on Aug 12, 2009
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
rburroak
  • 14 Answers
SOURCE: MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Posted on Jun 19, 2009
  • 30 Answers
SOURCE: I have a Craftsman Yard Man 6.5hp push mower with
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Posted on Sep 25, 2010
Mfg. year of Savage 720 serial no. 66499
we do not do guns here . try a gun store
Jan 11, 2016 | Motorcycles
How to take the flywheel off with the engine still in
You will need to remove the transmission or transaxle first and then you can remove the flywheel. You do not state model of car so I cannot give more detailed answer than that
Dec 18, 2015 | Cars & Trucks
Wadingriver, 536.881800 Craftsman. Don't see a fill plug. See it on the diagram, but not on the differential ....
Questions, Troubleshooting Help & Support Page 7 - Fixya
www.fixya.com/troubleshoot/page-7
wadingriver...it's 536.881800 craftsman snow blower...2004 Shows a fill plug on diagram but don't see any plug on the differential · Snow Blowers ' Answered 1 ...
Don't buy a Craftsman snowblower with a Briggs & Stratton ...
? 2:50
https://www.youtube.com/watch?v=cBfglXb9hx4
Aug 15, 2011 - Uploaded by dannylafrance19
Don't buy a Craftsman snowblower with a Briggs & Stratton motor .... These should be a metal plug (like the drain plug) on these models that do not ... With the vibration of these engines,one cansee how these may eventually ..
Nov 24, 2015 | Cars & Trucks
What happened to cause the engine on a Snapper riding mower to emit white smoke?
maybe low on oil, black smoke is when theres oil in the muffler, could be a blown headgasket, pistion rings could be fried also
Jun 01, 2014 | Snapper Garden
Overheating briggs & stratton motor model #126t02-0487-b1
what do you mean by overheating make sure all the fins in engine are clean and free of debris and also the top of flywheel is clear as well it must be to keep it running cool
Jun 04, 2013 | Garden
B&S 300 series 148cc walk behind side discharge mower emits white smoke on start up
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 04, 2012 | Cars & Trucks
FC540v Kawasaki john Deere 265, bugs down under load,emitting black smoke & then dies. Works fine without air filter.Carb cleaned, Compression check has 80 lbs
Thanks for your attention to this matter.
Aug 29, 2012 | Cars & Trucks
Microwave only stay on for 1.5 minutes at 100% power
Take it back you still have warranty, the problem is the magnetron, or the inverter board, and possibly the keypad control board.
May 18, 2012 | Panasonic Microwave Ovens
Garden Logo
409 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
