Question about Zanussi FJS1225W Front Load Washer
Zanussi error code 30(model zws 1640s)jetstream time line.
Washing machine will not fill with water,replaced selodoid no luck do you know what the error code 30 is many thanks freddieboy
  • 2 more comments
  • fred jackson Aug 06, 2007
    there is no water going into the machine at all ,clothes are put in door shuts i turn the knob to the wash i want ,press start and it makes its usual noise then nothing it then flashs E30 error code .i have changed the solenoids for brand new ones thinking that would be it but alas no.i have a meter how do i test if its getting power many thanks freddieboy.
    yes i checked the the in line filter that was okay i have just tried it again and its started working again but saying that it has done this before it works one minute and does a wash then it wont and flashes up the e30 code its been doing this for a week now.
    its stopped working again,is there a list of all the error codes anywhere or are they all secret
  • Anonymous Mar 14, 2014
    I had a whole in the seal, replaced the billow and now have a f8 e1 code....could it be that the seal is not lined up...I was careful to line up correctly
  • 641 Answers
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Posted on Aug 06, 2007
  • Dov Dror Aug 06, 2007
    Did you cleaned the water inlet line filters ?
    Adjast your multi-meter to AC volt (the range should be more than 220v) and touch with its probes on the solenoid tags.
SOURCE:
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
327 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
