My Lenovo G480, window 8, half way doing work, screen become green, then shut down. When I on it back, the power LED is on, processor fan is moving, but screen in black n not functioning... How to save it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Reinstall windows, or Factory reset...
Posted on Jun 06, 2013
  • 263 Answers
SOURCE: presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Posted on Jan 05, 2008
HW_Dude
  • 87 Answers
SOURCE: hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Dell computer won't start up.
if you have 2 memory sticks, (i.e. 2 ram sticks that are 2 gb each) try putting on in and start it.  if it does not work try this.
remove all power supplies (cord and battery).   hold down the power button for 30-60 sec.   after that plug the power in and try turning it on.
Posted on Mar 09, 2009
  • 3940 Answers
SOURCE: Laptop Screen Freezes and turns black When Adjusted angle.
It is possible that the video cable is chafing in the point where it passes through the hinge assembly. Try reseating the video cable, if that doesn't help, the replacing the LCD cable assembly is the likely fix.
Posted on Dec 05, 2009
MUKHTAR
  • 2022 Answers
SOURCE: I have a Lenovo 3000 N200 0769 with a black screen
First you try with removing the ram and clean it and insert it again also if you have tft monitor just connect the vga cable and see are you getting the display on tft screen.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 31, 2010
My Lenovo Yoga tab 3 keeps shutting off and going back to the locked homescreen. It does it all the time, i cant really do anything on it w/o it shutting off. Any awnser?
Does it shut down, then restart? Or does it go back to locked screen but stays powered up?
If it shuts down, the processor could be over-heating. This means cooling fan might be broken or running too slow.
If it just restarts, then check your settings in the 'power-saving' section, assuming your're on Windows OS.
Oct 06, 2016 | Lenovo Computers & Internet
Gateway laptop stayed on blue screen and it says intalling updates but hasnt moved from 1 of 159
The only thing that you can do at this point is Shut it down. If this is windows 10 it will recover by itself when it powers back on. To shut it down you can hold the power button down for 10 seconds.
Sep 28, 2015 | Gateway NE52204u Silver 15.6" Notebook 1.5...
Osd not working in lenovo g480
Cusious, windows 8 or any other should not avoid the monitor OSD
I would suggest trying the monitor on another source and see if still OSD not functionning. then if it is the case the OSD menu button can be stuck (does not give the signal)
try to work the thing from there.
Jan 03, 2014 | Lenovo Computers & Internet
Auto shutdown during work
it could be that the fan of your processor stops working or not working at its full efficiency, you should check underneath your laptop unit if the processor fan that blows away the heat generated by processor and chipset during heavy load of work.
Oct 21, 2013 | Lenovo Computers & Internet
Lenovo g480
Turn off your computer. Remove charge. Remove battery. Hold down the power button for a minute. Connect only power cord and restart it.
IF not working, then you need to either replace charger or it is an issue with connecting port.
Jun 02, 2013 | Lenovo G480 218422U Dark Brown 3rd...
Lenovo G480 cant adjust screen brightness! please help
On AC or Battery? As I'm sure you know, your Laptop will dim the Display on Battery to save power. In Windows 7, Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, set Display time, set Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one by one and adjust. OR right click a open spot on the Desktop, select Personalize, left bottom select Display. adjust to your preference.
Apr 16, 2013 | Lenovo G480 218422U Dark Brown 3rd...
Hi i am unable to update preinstalled version of windows 7 home basic on my lenovo g480. everytime when i shut down, it installs updates and when i restart it tries to configure but then there comes a...
Make sure the account you are logged in as has Admin privileges, and manage updates yourself. Choose and only install those updates pertaining to you. Like not installing languages updates and so on.
Oct 31, 2012 | Lenovo Computers & Internet
Sometimes when I shut down my laptop when next I want to power it,it will only show the power led,the screen won't display,the memory is ok.but anytime I loose the cooling fan from the processor and I...
It sounds like its overheating, but don't try and run the system without the heatsink and fan in place as this is sure to burn out the processor.
You need to make sure the heatsink is sitting on the processor and you should apply some thermal paste where the two meet to aid cooling. Make sure all the vents are clear of dust and the fan is working and is clean & is on the right way round, i.e. blowing down on the heatsink.
Mar 13, 2012 | Gateway Computers & Internet
My one and a half year old Lenovo SL500 is getting extremely hot under the left side of the machine... I can hear the fan working hard almost all the time. I am scared that something will be...
The ThinkPad SL500 usually comes with a Core 2 Duo processor, which is a fairly powerful processor. You may also have chosen to buy a discrete graphics chip with the laptop (instead of using the Intel Integrated Graphics). System components like these generate a large amount of heat. It is the fans job to push this heat away from the precious system components. This is very difficult in a laptop, because the components are very compact, and the only way for heat to escape is through the sides (heat wants to rise). When doing processor or graphics intensive tasks (such as editing/encoding a video or watching a move in High Definition), the fan has to work near its maximum to keep the computer cool. While it may sound intimidating, the fan will never push itself to a breaking point unless there is a problem with its design, in which case Lenovo will pay to get you a replacement. Even if there is a problem, if the processor gets too hot, the computer will instantly shut itself down before any heat damage can be done to the components, and you will be certain that the laptop has faulty hardware.
Feel the side of the machine where the exhaust comes out; you should be able to touch it for a few seconds without burning yourself even while doing intensive tasks. If it is too hot to touch, you may want to contact Lenovo and see what they say.
Mar 20, 2011 | Lenovo ThinkPad SL500 Laptop Computer...
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
