I've read the service manual on how to change the belt. Are there any tricks to making this an easier process? Do I really need cable tool (P/N 105-6819)? Can any other tool be used? Thanks
SOURCE: need to change drive belt need service manual
If you go the internet and find your tractor you will find that manual on line. I had the same problem with the same type on tractor
Posted on May 17, 2009
SOURCE: Manual for a 917.251522
if you go to searsparts.com type in the 917 # it will show you and exploded veiw of the entire mower ? you have to removwe the deck to get access to this belt you may also have to loosen the crankshaft pullie bolt to get it around it ?
Posted on Aug 31, 2009
SOURCE: need to replace high pressure power steering hose
Power Steering Line/Hose: Service and Repair
Pressure Hose
Power Steering Pressure Pipe/Hose Replacement (3.8L)
Removal Procedure
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly.
5. The power steering pressure hose is the lower hose at the power steering gear.
Remove the power steering pressure hose from the power steering gear.
6. Remove the power steering pressure hose from the power steering pump.
7. Remove the power steering pressure hose from the clamps on the power steering gear.
8. Remove the power steering pressure hose from the vehicle.
Installation Procedure
1. Install the power steering pressure hose to the vehicle.
2. Install the power steering pressure hose to the clamps on the power steering gear.
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the power steering pressure hose to the power steering pump.
^ Tighten the fitting to 27 Nm (20 ft. lbs.).
4. Install the power steering pressure hose to the power steering gear.
^ Tighten the pressure hose fitting to 27 Nm (20 ft. lbs.).
5. Install the tire and wheel assembly.
6. Remove the drain pan from under the vehicle.
7. Lower the vehicle.
8. Install the accessory drive belt.
9. Fill the power steering system with power steering fluid.
10. Bleed the power steering system.
11. Inspect the power steering system for leaks.
Posted on Sep 15, 2009
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
SOURCE: My gts Toro mower Model 20070 will not start with
Try this; take the air cleaner element out and squirt some light oil (like WD40) into the carb and immediately try the starter, if the engine starts right up it likely needs new rings.
Posted on Jun 16, 2010
Sep 05, 2014 | Garden
Jul 15, 2014 | Toro Garden
Sep 11, 2011 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Aug 06, 2011 | Toro Power Lawn Mower
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
May 14, 2011 | Toro Lawn Mower With Toro Power Tools
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Feb 10, 2011 | Garden
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
187 people viewed this question
