Question about SanDisk Sansa e250 MP3 Player
Corrupted files Ok so one day I just connected my mp3 to charge it and when I disconnected it I tried to play my music and it showed only 60 songs and I deleted every thing so I thought but it showed there was something taking up all the space. Then I started messing with my SanDisk and I uncovered the hidden files. So I went straight to the system?s music and found some folders that had some weird signs like: ?╜ T and I thought that was the problem but they can?t be deleted. Now all the songs I add won?t play. p.s. I already put RESET ALL and nothing happened
  • Anonymous Jan 08, 2008
    ive deleted every thing on my e250 and the piece of crap is saying a gig and more is being tooken up by nothing need help
  • 80 Answers
All i can say is try to format the mp3
Posted on Aug 07, 2007
SOURCE:
Mp3 shows no files however, music has been loaded
delete the music when you connect to the laptop. after deleting transfer the songs back again. this should solve it if not hola back ok
Mar 13, 2010 | Ego MD210 (128 MB) MP3 Player
Rizone 32gb. Only charging to 3 bars instead of 4 and this takes hours and hours. Can't find shuffle setting and can't drag and drop music. On screen it shows as gone in but when i check player music has...
To charge your player, with the player on OFF, connect it to a computer or other charging device. Then, after everyting is connected, then turn your player to ON. (For some reason, my player doesn't charge if it is already ON while being connected to the computer or other device.) It will charge.
This is the solution that I use for the music. Connect you player to the computer. Turn it ON after being connected. Go to FILE NAVIGATIONN. Copy your music there. (not in any forler, but as a separate entry in FILE NAVIGATION) Next, disconnect your player from the computer. (Use the SAFELY REMOVE HARDWARE feature for this.)
On the player, there is a PLAY button (NOT THE ONE MARKED "M", BUT THE ONE WITH THE RIGHT FACING ARROW WITH THE TWO BARS) next to the volumn button. After going into the FILE NAVIGATION menue, scroll down to the song(s) and/or music you want to move. Click the song using PLAY. You will see three options: MOVE, COPY, and DELETE. Scroll down to the MOVE option. In the main menue of FILE NAVIGATION, scroll down to MUSIC. Now click the "M" button (the one next to the button with two arrows and one bar). A screen will come up that says that the file is being moved. The song will now be in the MUSIC folder.
You could use the COPY or DELETE features for their respected funtions if you want to when these functions appear.
This is as complete as I can make it.
Jun 27, 2009 | Audio Players & Recorders
SanDisk freezes when trying to play a song, then it restarts itself.
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works.........Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....
Then disconnect from your computer and see if it worked
Hope it does..........Please rate
May 17, 2009 | SanDisk Sansa e260 MP3 Player
Having problem syncrinizing music to mp3 player
if u used window media player its will mess up your mp3 by duplicating songs and not leting u play songs. What i do is connect it to the computer and it should pop up. DONT open window media player. Open the files and add your music by dragging them into your mp3 from another folder. This only works if you have a different folder of music. It should work. If all your music is in Widows media player it wont work. Also try deleting all your music from ur mp3 but copy your musice onto your computer first. Good luck i hope i helped.
Apr 08, 2009 | Philips GOGEAR SA6045 MP3 Player
It won't let me delete songs
  1. We Too had a hard time deleting a song but found the solution..... Put the mp3 play in the MSC mode through the settings do not put in auto.....when your computer prompts that the music player is connected it will have a screen that asks play music, open folder to veiw files..... or take no action... you neew to click on the open folder to veiw files..... when this screen loads find the song or songs that you want to delete right click and then delete it will only delete from the mp3 player.....took me two days of pissing with this mp3 player to figure it out......
Dec 15, 2008 | SanDisk Sansa m250 MP3 Player
EMERSON MP3 MUSIC PLAYER, EMP312-1, "FILE SYSTEM" ERROR
ok here we go i dunno how i figured this out lol but it took a while. okay so ur gonna go to control panel, device manager, and uninstall the driver for mp3 player. then disconnect mp3 player and reconnect it to reinstall mp3 player. it will recognize it as emerson mp3. right click on it (im running xp) go to properties, click on the tools tab and click on check now on the error checking and select both options of automatic fix file system errors and scan for and attempt recovery of bad sectors. then hit start and it will start the process of fixing the file error. it takes a couple minutes and when its done disconnect the mp3 player n turn it on and voila!!! it works again. if u need more help u can e-mail me at [email protected] hope this helps yall so u dont throw them away
Oct 27, 2008 | Audio Players & Recorders
My ipod shuffle wont play music
It won't play music while connected to computer, that's for sure. It only plays when it's disconnected from the wall charger and computer.
The songs could be in the wrong format
AAC is iTunes native format
Mp3 generally works
WMA is iffy - only unprotected (non-DRM) files will work
Streaming songs won't work
-Tha Mp3 Doctor
Aug 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Sandisk 240 1.0 gb
I had this same problem. What I ended up doing was going into My Computer into the device itself and seeing what showed up. It appears a few new songs I popped on there the day after were appearing but nothing else. I deleted all the files, unplugged it from the computer and let the library update, old songs were still playing. Plugged it back into the machine and voila they showed up.
Aug 05, 2008 | SanDisk Sansa m240 MP3 Player
All it does is Beep!
Mine did the same thing when i first got it. when you hook it up to the computer is it off? How old is the usb whire and have you ever droped it befor?and dont use rhapsody any more. blood thirsty ruin ur day parisites sneak in virises for mp3 players with your song.
Jun 19, 2008 | Insignia Sport MP3 Player
Synchronize to continue your music subscription
it's asking that you verify the DRM status (i.e., that you bought it and it resides on YOUR computer.) It cannot play the file until you synchronize it with windows media player. You can delete them off of the MP3 player just by noting which songs don't play and deleting them through windows explorer when the player is connected.
Mar 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
