Question about ChicBuds Chicboom Speakers Pink Leopard Keychain Speaker Small
Have the pink leopard print mini speaker, light goes on to charge, but after charging wont work. hardly used, never dropped, always kept in a safe little case when not in use.
All I need to know is, for how long do these mini bombspeakers need to charge?
Who knows, but if you charge it overnight, and it's not working, either your
  • charger is bad;
  • or it's not charging.
I've never seen anything chargeable that doesn't have a charging indicator. If you don't get that, it's probably broken. They're all simple, if not always cheap, and one amplified mini speaker is like any other mini-speaker.
  • You could always try to replace the rechargeable battery inside too.
  • This might require soldering skills, but, even that's fairly easy for a beginner.
Sep 02, 2015 | Audio Players & Recorders
Marware mini speakers only work when connected to hard drive
Use an AC Usb charger.
Find out how to reset the speakers.
And it's computer, not hard drive.
Apr 22, 2014 | MarWare UpSurge Mini Speakers
My bose soundlink mini won't charge or turn on worked fine for a while but now the red battery light is flashing fast every time I try to charge it it's been on the charger overnight and is still doin so...
I love my Bose Soundlink Mini 2. But, I faced a few issues sometimes.
Speaker not turning ONSpeaker not charging with the battery LED blinking.Speaker not getting connected to the bluetooth devices.
But all were fixed by reading through the Manual a bit. To help others, I actually made a video, to show some troubleshooting tips for the Bose Soundlink Mini 2. Checkout the video, if your speaker is not turning ON / not charging / bluetooth not getting connected:
This seems like a very common issue for the soundlink mini 2. This is due to a firmware bug. Gets foxed with a hard reset.Check the video for details and other trouble shooting tips.
Feb 22, 2014 | Cameras
How to reset my kocaso nb726a
iv been charging my new kocaso 7 in nb726 and wont charge up and wont turn on at all nothing been charging longer than 4 hours
Feb 25, 2013 | Kocaso Pink NB726A 4GB Android 4.0 1GB RAM...
DS lite was dropped and now it won't work.
They usually don't work properly after they've been dropped. Nintendo carries a 1 year warranty, they will replace it for free (but not if you've used cheat codes (Action Reply), etc). I wouldn't mention that you've dropped it when calling them.
Mar 28, 2009 | Nintendo DS Lite Pink Console
Panasonic Lumix DMC FZ20
In case new batteries will not solve your problem and since your camera is still under warranty you should ask Panasonice to take care for it !!!!! Good luck!
Aug 29, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic PV-GS19 Mini DV Digital wont turn on
I have about 2 dozen of these that my students use at my school and the power supplies are kept in a locked room only to be used by me. The reason? They get easily damaged. The little metal part that plugs into the back of camera is often the culprit. If the power supply/charger is pugged in and the metal tip at the other end touches anything metallic (keys, metal tripod, etc.), it will short out and render the unit useless. If the amber light doesn't go on on the charger, and you are sure you it properly connected to a power source, then my guess is that it's a damaged power supply. You can purchase a new one online at Panasonic Go to this link and click on the Parts locator link near the bottom of the page. http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?storeId=15001&catalogId=13401&displayServiceCenter=false&displayPartsLocater=true&itemId=88739&catGroupId=25203&displayTab=A&surfModel=PV-GS19&surfCategory=Camcorders%20with%20SD
Jun 30, 2007 | Panasonic PV-GS19 Mini DV Digital...
ChicBuds Chicboom Speakers Pink Leopard Keychain Speaker Small Logo
27 people viewed this question
Top ChicBuds Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ChicBuds Audio Player and Recorder Expert? Answer questions, earn points and help others
