Question about Toshiba 43H70 43" Rear Projection Television
43H70 picture wobbling
On occasion, the picture appears of wobble rapidly. The picture also lookes curved at the top and bottom of the screen. This particularly noticeable when you are viewing a widescreen movie when the black are meets the pitcure. This wobbling occurs for a while and then it will stop but it may happen again. There seems to be no pattern. I have met with 4 TV repair people and no luck yet. Also, I live in Baltimore County, Maryland. Do you know of any repair places that fix Toshiba. Can anyone give me a suggestion. Thanksabunch.
    Sergeant:
    Champion:
  • 375 Answers
Possibly leaky cap in power supply,look for a 1000mfd/16v cap in on near the b+ supply and also cold solder connections.
Posted on Sep 12, 2007
SOURCE:
Why does the scene look wobbly on view finder?
Your in zoom mode. Go back to wide angle mode,.
Aug 13, 2014 | Cameras
Front driver side cv joint?
could be top/bottom ball joint easy to check ,jack up so wheel off ground hold wheel at 12 o'clock and 6o'clock (the position not the time) and wobble back and forwards then do the same but holding at 3 an 9 if notice movement further investigation needed,while you wobble wheel get someone too look at top/ bottom ball joints ,track rod end if they dont appear to be moving then more than likely bearing this is best done with vehicle on a lift but should be able to carry out on the ground the cv joint could also be responsible but would need a garage to determine as a bit more complex
Apr 02, 2014 | 2007 Ford F-150 Super
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
Dell Latitude D620 Nvidia Quadro NVS 100m
Suspected it's a graphic error. Try re-installing your video driver to it's later version.
May 30, 2009 | Dell Latitude D620 Notebook
Front end wobble
New blacktop will often give you a squirmy feeling especially in heat and on curves.
Nov 20, 2008 | 2004 Harley Davidson FXST - FXSTI Softail...
Gateway M275 Screen Wobbes
There are 4 screws on bottom too.
Aug 24, 2008 | Gateway M275 Tablet PC
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
Wobbly picture
The problem is static and a high density. Try a magnet by the screen or if you have a magitizer on your monitor that might work. something by your monitor is making it wobble.
Nov 26, 2006 | Taxan Ergovision 735 TCO 99 17" CRT...
Toshiba 43H70 43" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
