Question about Car Audio & Video
Wiring Diagram NEED DIAGRAM TO CONNECT RADIO
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Car Audio & ... Master
  • 102,366 Answers
What make and model radio?
Posted on Apr 27, 2013
  • 10 Answers
SOURCE: wiring diagram
Here's a link for a similar model. The wiring should be the same: http://panasonic.com.au/content/library/files/F001428.zip Most aftermarket car audio built in the last 15 years use the same eia wiring codes. They are as follows: Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Geen Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Posted on Sep 03, 2007
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Posted on Apr 15, 2008
SOURCE: need help
for the pioneer mosfet50wx4...hold clock and audio with unit off til clock flashes, use up and down arrows to change hour, use side arrows to switch to minutes than use up and down buttons to change minutes. When set just hit clock again
Posted on Oct 11, 2008
  • 20 Answers
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
Posted on Aug 11, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
What is the pinout for this radio that was in a Hyundai Santa Fe 2005?
Do you need Wiring Diagram for hyundai santa fe.Or you need where the radio fits in hyundai santa.The connector of radio.
Please Check the link mentioned below it has all wiring diagram for hyundai santa fe radio.Also it has details for how to connect radio connector.
http://www.allcarhelp.com/2016/05/hyundai-santa-fe-radio-wiring-diagram.html
If you need anything else,please reply.
Thanks.
May 11, 2016 | Hyundai Cars & Trucks
Vw golf VII radio wiring diagram
Hi. There should be a multi plug diagram on a sticker on the radio itself.
Jul 13, 2014 | 2014 Volkswagen GTI
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
I need wiring diagram for my truck
Try WWW.Crutchfield.com they have all the connectors you need to connect aftermarket units to the factory wiring.
Feb 07, 2010 | 1988 Ford Ranger
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I need an elecrical wiring routing diagram for a
Radio 12v, blue/red, +, radio harness
Radio Ground, black/yellow, -, radio harness
Radio Ignition, orange, +, radio harness
Radio Illumination, lt. green/red, +, radio harness
Factory Amp Turn-on, blue/black, +, radio harness
Power Antenna, N/A,,,
LF Speaker +/-, red - white," +,-", radio harness or amp
RF Speaker +/-, blue - yellow," +,-", radio harness or amp
LR Speaker +/-, purple - pink," +,-", radio harness or amp
RR Speaker +/-, white/blue - black/blue," +,-", radio harness or amp thats for non bose 04
Sep 21, 2009 | House Brand Car Audio & Video
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
