Question about Apple iPhone Smartphone
It wont let me press general in settings and i can barely access anything because its been like this for 4 days.
    Problem Solver:
  • 17 Answers
Turn the phone off then back on, if that doesnt work do a hard reset ( hold the home + power button )
Posted on Apr 28, 2013
My 1999 yahama big bear 4- wheeler wont fire, replaced all electric parts 4 cdi boxes and still wont fire can u help
are you getting anything at all?.....you could check your ground wire(s) to make sure they have good contact on the bare frame metal
Aug 30, 2017 | Yamaha 2005 Big Bear 400 4x4
Tip
Set up a GPRS data connection for email Please note: Please note that you need a...
Set up a GPRS data connection for email info.png boxAdd('subj0', cBoxClosed);
Please note: Please note that you need a POP3 email account in order to send and receive email messages on your phone. You cannot access web-based email accounts (e.g. Hotmail accounts). 1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
  • Key in one2one and press OK.
boxAdd('info6', cBoxClosed); The APN name general.t-mobile.uk must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • Key in general.t-mobile.uk and press OK.
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
on Apr 30, 2008 | LG KU990 Viewty
My iphone 4 power button does not respond on pressing. Please advise me what needs to be done. Should i change replace the power button or is there any alternate method?
I don't know about replacing it but you can use Assistive Touch ( Settings/ General / Accessibility / Assistive Touch on ). If your iPhone is jailbroken , activator is the best.
Aug 11, 2013 | Cell Phones
My iphone 3g wont let me on anything and it is saying everything eg; todays date and tells you to double tap to open things but does not allow access
u must have enbled voice over
to turn it off go to settings = general - accessibility then voice over set it off
hope i helped you
Jan 20, 2013 | Apple iPhone 3G
Don't know how to set the clock on the 9887 in-dash reviever
From the online manual: http://support.alpine-usa.com/products/documents/OM_CDA-9887.PDF
1: Press and hold Func./Setup for 2 seconds 2: Turn the rotary encoder to select General and then press play/pause/ENT 3: Turn the rotary encoder to select Clock Adjust and then press play/pause/ENT 4: Turn the Rotary Encoder to set year 5: Press play/pause/ENT 6: Repeat steps 4 & % to set month/day/hour and minute
Mar 05, 2011 | Alpine Car Audio & Video
I lost the manual, how do I set the day and time, and rings to answer. It picks up after 4 rings, can I set it for more rings? Thank you
I have this answering machine...
To set the day and time press the "REPEAT" button and hold it in. It will say something like "Time not set." and if you keep holding it it will say, "Monday." Now release the "REPEAT" button and use the "ON/OFF" button to cycle through the days. When it says the correct day, press and releasethe "REPEAT" button. Then it will go on to set the clock and you're done.
To adjust the rings, there is a slide switch on the top where the cords plug in. You can switch it to 2, 4 or TS (Toll Saver). Toll Saver generally lets it ring for about 5 rings before answering.
Nov 24, 2010 | Conair TAD2018CG Digital Answering Machine
How to set clock of the alpine CDA-9857 car CD/MP3 player
Setting the Time and Calendar
1 Press MENU to select SETUP, then press MODE.
BBE BASS ENGINE SETUP RETURN (OFF)
BBE
2 Press or to select the GENERAL mode,
then press MODE.
GENERAL TUNER AUDIO DISPLAY DEMO
3 Press or to select "Clock Adjust," then
press MODE.
4 Turn the Rotary encoder to set year.
5 Press MODE.
6 Repeat steps 4 and 5 above to set month, day, hour
and minutes.
If you need the manual you can get it on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9857.PDF
Good luck and please rate 4 thumbs up for the free answer
Sep 22, 2010 | Car Audio & Video
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
I can't figure out how to set this watch.
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
Mar 17, 2009 | Watches
Settings complications
To change the ring tone press the flash key, keep pressing the flash key to hear all 16 different tones.
If you mean 12 or 24 hour format, you cant change it.. its set for 24 hour format.
Good luck
Gary.
Jan 22, 2008 | Innovage Speaker/Caller ID* LCD Touch...
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
