Question about Sanyo Televison & Video
Screen goes dim
Its like a car signal. gets dim and then it goes back to regular. then goes dim. like it blinks or flashes what ever you would call it
    Top Expert:
  • Sanyo Master
  • 75,404 Answers
It sounds that its back-light have a problem. Check its back-light CCFL lamps, and back-light inverter board.
Posted on Apr 27, 2013
Signal lights on my 2003 monte carlo blinking fast.opposite side glows dimly. Changed signal/cruise/high beam lever, changed all bulbs, changed flasher and all fuses. still doing same thing.
4 way flashers work fine but when operating either signal light, they flash fast and side not turned on lights up also, although more dim than the side that should be functioning..
Apr 02, 2017 | Cars & Trucks
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
I hard wired my light housing and now my turn signal will stay on but it wont blink
Either its a problem with the resistance of the circuit or what i suspect is a flasher unit fault ,i have had this in the past where the hazard switch is faulty and doesnt connect the right connections inside the switch and this causes the problem but when it goes neither side will flash ,if you had wired it up wrong then it would flash very fast and a dim light .
Feb 14, 2012 | 2001 Oldsmobile Aurora
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
Laptop screen flashes... i.e.... goes bright then dim
Check your power supply. Maybe its wire is broken then intermitently making contact every now and then. Its my first suspect. Its like disconnecting and reattaching its power supply only in much faster way. Or test it with a good similar power supply if this will be the same.
Hope this one helps already.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Flashing screen
% blinks for your model means a video output abnormality. which translates into IC7101, IC7201 or IC7301 on C board circuit is faulty or else its transistors Q510, Q516 or Q524 are faulty on the A board. I would check the transistors first for being faulty and if they check out then suspect one of the ICs
May 12, 2008 | Sony KP-53XBR300 53" Rear Projection...
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
