Question about Belling BE811 Bottom Freezer Refrigerator
Belling intergrated Fridge Freezer
I dont have the manual as the fridge freezer was left in the house we bought. Im trying to defrost it but i dont know how to turn it off, i cant even find the plug!
    Novelist:
  • 87 Answers
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Posted on Aug 26, 2007
SOURCE:
Should I replace compressor in refrigerator
Im having the same problem! Every 2 weeks we had to power off the fridge and defrost the freezer, once we did that it was like brand new, cooled the botton fridge beautifly. Now we have to defrost every week. Its really irritating and dont know why we gotta defrost the freezer all the time to have the fridge cool down. We had a 3 month warranty and ofcourse it started to get messed up after the 2 months were up. Are you having the same problem?
Jun 30, 2014 | Danby DFF9102BLS Top Freezer Refrigerator
Hi my freezer is not keeping food frozen it starts to thaw after a few days i have cleaned the back of the fridge it is not up against a wall the door seal seems okay the compressor works as i can hear it...
the defrost heater or thermostat on the evaporator coil is bad,you can tell if the inside rear wall of the freezer is covered with frost,you need to remove this panel after defrosting with a hair dryer and find which part is bad
May 19, 2011 | Refrigerators
I have a GE Model #TBX18NI- 18.2cuft top freezer/refrigerator, and the freezer part is working great, but the refrigerator part seems to be getting warmer and warmer. I've tried adjusting the temp...
The frig has a defrost timer which activates an electric element which cyclially defrosts the evaporator in the freezer.If either the heating element or the defrost thermostat are faulty the freezer evaporator will freeze solid not allowing cold air circulation to the rest of the frig.
At a suiteable time empty fridge contents into insulated containers and turn fridge off at powerpoint and allow to fully defrost leaving doors open.The evaporator coil in frostfree is normally located behind the rear panel of the freezer.If you do not have defrost heater it will take 3-4 hrs for complete defrost.
After defrost turn fridge back on and make sure items to be returned to freezer are free from moisture and ice and keep freezer open for minimum of time as moisture will start building up onthe evapoator.
If the fridge works ok for a couple of days and the the original problem returns the problem is with defrost thermostat or defrost heater
Apr 29, 2011 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
The refrigerator door was left ajar for several hours. then the ref cooling system was not functioning right after the incident. although the freezer is still doing its job Im worried if its beyond repair....
When the freezer section gets cold and reaches its required cooling temperature,after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge.But if the defrost cycle does not start then freezer will block the air passing section from freezer to fridge,so the freezer gets cool but fridge section does not cool. Its the defrost problem.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check,if the same problem is noticed again,.If yes then its defrost board problem.The defrost board located in the back of fridge section.You can get required parts from www.repairclinic.com or from online sears part site.------------- Thank you.
Jan 31, 2011 | LG LSC26905TT Side by Side Refrigerator
I have an integra fridge freezer arl 7561g. one control only in fridge. how do i defrost the freezer and wot setting numbeer would i use in the fridge.thanks alot.
hi barbra,just turn the unit off at the mains and let it defrost NATURALLY.(dont use a hairdryer)best left for 24 hours to clear ALL the ice.then clean out and dry,(use bicarb to clean)when fully defrosted, turn on,and let it return to cold then use a fridge thermometer to set the fridge at +5c (keeps lettuce crisp not soggy)you may have to turn the setting up/down depending on ambient temp in room.
A full defrost should be done even if "frostfree"at least yearly(gives you a good excuse to clean out the unit).regards.geoff.
Nov 26, 2010 | Refrigerators
Magic chef mcbr1010w, fridge not getting cold. freezer is not defrosting ice blocking hole down to fridge. love the fridge dont want to get rid of it. but im having to defrost freezer by hand every...
do a total, 24hour,defrost,with the doors open,(loads of towels)this should melt all the ice you cant see/get at.DO NOT use hairdryers/scrappers as they only do the surface ice.Wash out/spray all vents/drains with clorine bleach.(clorine is a gas and the smell will not permeate food if left to vent naturally) then switch onto fast freeze,check door seals are tight all round(hot cloth will help mould them).hope all works well for you/please leave feedback.ta!
Sep 22, 2010 | Refrigerators
Frigidaire fridge freezer not getting cold
Louise, this is a big area. I would switch off the fridge, look at the back where you see the" box things". You should see a timer which is white or black (wires comming out of it).. It has a short type of knob which can be turned manually clockwise.. Turn about a 1/4 turn then try and switch on again. If not, thermostat will be the problem. Assuming you never disrupted any wires.
Nov 13, 2009 | Frigidaire Freezers
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Belling BE811 Bottom Freezer Refrigerator Logo
659 people viewed this question
Top Belling Refrigerators Experts
Reynaldo Nunez
Reynaldo Nunez
Level 1 Expert
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
