Question about Carlon Wireless Doorbell system with volume switch
Carlon RC8800R - doorbell won't ring with new batteries?
Do we need to reset after adding new batteries?
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
How do I change the battery on the Door Push Button?
Easy....You'll need a very small screw driver. There's a small hole on one of the long ends (most are rectangular in shape). For the brand of door bell I have (Thomas and Betts/Carlon), you push in and downward with the screwdriver. This pushes out the bottom (back of doorbell button). In my case, there are (3) CR 2032 Button Cell batteries in a stacking position. As a quick side note -> If your wireless doorbell button does use button cell batteries. Look to Ebay to purchase them. You can get 6-10 batteries shipped to your front door cheaper. Rather than 3-4 batteries at a retail store + tax...Hopefully, I have lent you some assistance...Thanks for reading
Apr 25, 2015 | Carlon Wireless Doorbell system with...
How do i add a second switch to my rc8233r?
I would try Ebay first (or search the net for availability and prices). I bought CR2032 3V Button Cell (that are used in my Carlon door chime buttons) batteries. I got 10 for under $5. Carlon (Thomas & Betts) still makes a variety of door chimes and accessories. However, on their site, the prices are atrocious. But, I think that Thomas & Betts deals in bulk (as in dealing with retailers). Because they list their items in bulk price form. I personally have 5 T&B wireless door chimes. Hence, 4 of the buttons are in storage. Out of curiosity, I tried all of them. All 4 extra buttons rang all the door chimes. Caution, on the packages of the door "chimes" I purchased. There's a blurb on there that states the wireless buttons for the "door chimes" will not work with the "doorbells". If you have the packaging for the one you have. It will explain. I'm not positive, but it seems the variance is due to whether you use battery or electric powered models. Hope I was of assistance...Greg
Jul 20, 2014 | Carlon Wireless Doorbell system with...
How do you change the battery in the door button
There's a notch/opening on one of the short sides of the button. Use a small ( I mean 1/16 inch) flat head screwdriver. Press inward, then downward. It will pry the inner part downward. Once you see the inside, you'll see the batteries. It takes 2 (maybe 3) CR2032 3 Volt Button Cell Batteries. Retail prices are expensive. So, it pays to search the net for best prices. If you use Ebay, better yet. That's where I get them. You can get 10 of them for $5 on Ebay. Hope I was of assistance...Greg
Jul 15, 2014 | Carlon Wireless Doorbell system with...
Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Cheers
Feb 26, 2013 | Desa International White Wireless Plug In...
Carlon RC8800R how to set chime for westminster crime
The Carlon RC8800R door chime, quicks chiming usally within two days of mounting the base unit interior wall. If I take down and re-arrange the 4-D size batteries in sometimes starts chiming again. Is the base unit just a "lemon"?
Nov 29, 2011 | Carlon Wireless Doorbell system with...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
Carlon Wireless Doorbell system with volume switch Logo
37 people viewed this question
Top Carlon Home Security Experts
Tom Chichester
Are you a Carlon Home Security Expert? Answer questions, earn points and help others
