Question about Garden
Snapper sr1030 front tires pulled away from the wheel
3 Suggested Answers
  • 3074 Answers
SOURCE: hi, i have an snapper riding lawn mower model
http://www.ehow.com/how_6402951_change-snapper-mower-belt.html
Posted on Apr 03, 2011
  • 320 Answers
SOURCE: i have a snapper sr1030 but it is not firing i have replaced spark plug
It will take 3 things to make it run. Fuel, fire and compression. Try this. Squirt a little starting fluid in to the carburator and try to start it. If it fires you then need to check to see if there is gas getting into the carb. If it doesnt fire, you are not getting any spark due to a shorted coil, bad coil or shorted wire. If it has been outside for a while where it is damp, your magneto and coils may have enough rust on them to prevent them from firing.
Posted on Mar 13, 2012
My tires on my snapper roll like there is a flat or low air pressure, but this is not the case. Anyone got any ideas?
Eloise, it could be your friction wheel, it is what drive your wheels to make them go around, symptoms could be jerking/slipping when driving or it may not move at all. let me know if this was helpful info. by pressing the helpful button. good luck with your lawn tractor.
You were at one of my other post, but thought it was Warren, if you go there you can click on the links and learn about the friction/drive wheel.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jul 20, 2016 | Snapper Garden
My snapper mower LT12D41 rod to connect two front tires came off
it's called the Tie Rod, and there are usually bolts at each end that holds a swivel to the sterring knuckle.
Jul 15, 2014 | Garden
Snapper sr1433 mower
Here is probably what you are looking for. http://www.amazon.com/11x400x4-2ply-Turf-Saver-Carlisle/dp/B005C9Q22E/ref=sr_1_8?s=lawn-garden&ie=UTF8&qid=1382349922&sr=1-8&keywords=4x11x4+tire
Oct 10, 2013 | Garden
Snapper sr1433
check harbor freight for something close 4.10/3.50 x 4 tire with wheel...
keep in mind that the bearings in the wheels can be changed and you might need to use washers as spacers. check a local dealer as well
Steering tracking to the right
Please check for a dragging LF caliper. Then be sure the front tires are at the same PSI. Then be sure the problem is not caused by the tires.*
Miss matched BRANDS,sizes or unusual wear patterns on one or both tires will cause a pull.
Tires look good? Rotate them,one side at a time until pull goes away.
Also, to see if it IS a tire problem,swap left to right and see if it pulls to the right.Easier to do that,first.
One more test: With you hands off of the steering wheel,start the car. If the steering wheel jerks to one side,you may have a bad /plugged spool valve inside the rack and pinion.
* I have seen that happen with NEW tires.
Mar 07, 2013 | 2007 Toyota Dyna
Snapper sr1030 mower
This question is to vague,to answer! Sorry,Sincerely,Brad Locke DTD 12/04/15
Aug 18, 2012 | Sears Garden
Snapper riding mower runs but wont pull itself
first check the friction wheel that drives the rear axle then look at the cable adjustment you may need to move the small rings around the pedal if all that looks good loosen the pulley assem away from the engine closer to the axle
May 16, 2012 | Garden
My snapper won't pull forward but will back up
You're in luck, if your Snapper is of the type with a record player drive. Let me explain myself. Look under the motor. You should see that the shaft connects to a disc that has a rubber coated drive disc (or tire) under it. Works like this: when you are in the forward speeds, the tire is on one side of the disc. When in reverse, the tire moves to the other side. This means to me that it is neither your clutch or axle. Snapper dealers sell a tool that allows you to adjust the friction of the record (disc) against the drive wheel (tire). You loosen two allen screws on the disc where it mounts to the motor shaft, and the special tool screws into the center of the disc. With the tool installed, you screw down the jack screw to tighten the disc against the drive wheel. You then tighten the allen screws back up and you're done. Sounds too easy, 'eh? There are other variables you'll need to consider, mostly the condition of your drive wheel. The rubber on it will wear over time, so look at it carefully. If it is cracked or damaged, it should be replaced. It's easy to do. What about costs? Good question.... It's been a while, but best I remember, the speciality tool is ~$20. You'll need a long allen wrench to fit (~$2), and maybe the drive tire (~$15). The best news is that the speciality tool lasts virtually forever, and you'll use it again if you keep your Snapper
Hope that you have found this to have been helpful.
Best regards, --W/D-- Please feel free to rate this solution!
Jul 26, 2009 | Garden
Snapper won't go forward but will back
You're in luck, if your Snapper is of the type with a record player2.gif drive. Let me explain myself. Look under the motor. You should see that the shaft connects to a disc that has a rubber coated drive disc (or tire) under it. Works like this: when you are in the forward speeds, the tire is on one side of the disc. When in reverse, the tire moves to the other side. This means to me that it is neither your clutch or axle. Snapper dealers sell a tool that allows you to adjust the friction of the record (disc) against the drive wheel (tire). You loosen two allen screws on the disc where it mounts to the motor shaft, and the special tool screws into the center of the disc. With the tool installed, you screw down the jack screw to tighten the disc against the drive wheel. You then tighten the allen screws back up and you're done. Sounds too easy, 'eh? There are other variables you'll need to consider, mostly the condition of your drive wheel. The rubber on it will wear over time, so look at it carefully. If it is cracked or damaged, it should be replaced. It's easy to do. What about costs? Good question.... It's been a while, but best I remember, the speciality tool is ~$20. You'll need a long allen wrench to fit (~$2), and maybe the drive tire (~$15). The best news is that the speciality tool lasts virtually forever, and you'll use it again if you keep your Snapper
Jul 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
