Question about Toshiba TP55F80/81 55" Rear Projection Television
TP55f80 I some information how to place the lenticular screen of my Toshiba 55". Where can i get this?
Call Any Toshiba authorized service dept. The part is still available.
Posted on Feb 25, 2008
  • 87 Answers
The lenticlualr screen part number is 23837437. the part is no longer available.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Aug 07, 2007
6ya staff
SOURCE:
Broken screen
Lenticular ( front ) # 23430608
Fresnel ( rear ) # 23430607
I have tried 5 different wholesalers and all said No Longer Available
If you do find them, yes you can replace them yourself.
Jun 25, 2009 | Toshiba TP55G60 55" Rear Projection...
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Tp55f80 tv. to much red on screen
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Feb 17, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Red Screen with Vertical Concave Lines
Check the transistors and resistors on the CRT socket circuit board itself. Also try turning down the red drive a little this may eliminate the lines.
Feb 02, 2008 | Toshiba TP55F80/81 55" Rear Projection...
Lenticular screen for TP 55 H60
Mit has screens that are second to none, if you can't find an official Tosh one. It might need to be cut to size, but no biggie -
Mr Bob
Jan 09, 2008 | Toshiba 55H70 55" Rear Projection...
Lenticular screen
Don't know if a fix is still needed, but I ordered a replacement screen through a Toshiba dealer and received it within a week.
Oct 17, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Toshiba TP55F80 convergence problem?
check the convergence chips for bad solders or even the crt sockets, I would lean more on the ic's and surrounding area.
Apr 18, 2007 | Toshiba TP55F80/81 55" Rear Projection...
TP55F80/81 55 in
no mater what I say you will need a tech, is note that you dont have experiece with this tv, so let the job to a tech, is better for you...good luck
Aug 09, 2006 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
