Microwave trips breaker
Sometimes throws breaker on startup
    Top Expert:
  • Heating & Co... Master
  • 43,059 Answers
It is recommended that microwave ovens be installed on a separate line. If your oven is connected to a shared line and some other device is drawing power when you start the oven, it may cause the breaker to trip
Posted on Apr 27, 2013
MOD# C880-6402990 ser IMF0216838 Type 30S My issue is I had my microwave plugged into the extra outlet. I turned on the microwave and then it seems like it tripped something in the stove.
Check the circuit breaker for the house. It might be tripped. Sometimes a breaker will trip without moving the handle to indicate a trip. Reset the breaker several times.
May 15, 2017 | The Kitchen Appliances - Others
When open door trips breaker sometimes
has the cooking cycle stopped when you open the door
in these breaker trips
if no
stop the microwave before opening the door every time
if yes ..it has stopped
faulty microwave ...
you could try to replace door release catch
but think there is more to the breaker trip with the unit
time to toss it out and replace it
Jun 02, 2016 | Kenmore 1.7 Cu. Ft. Over The Range...
H7871SOGB/03 combi. Why isn't it working?
The fact the breaker in the fusebox tripped indicates a fault in the appliance that is probably safety related. If it was the mcb (micro circuit breaker) it indicates a sudden overload. If it was the rcd (residual current device) it indicates there might have been a live circuit shorted to earth.
The fault is likely to be internal and it is potentially dangerous for unqualified people to fiddle about inside microwave ovens. Many brands are cheap throw-away items these days because a visit to the repair shop tends to cost more than a replacement.
The Neff brand is a premium brand and although repair costs are expensive it is likely to be (marginally) cheaper than a replacement.
Sep 04, 2015 | Neff Microwave Ovens
Lg microwave mv2297fspl
Magnetron is gone, just to be sure remove the microwave and use on a different socket. sometimes the breaker becomes faulty after 10 AMPS.
Tony
Nov 21, 2013 | Microwave Ovens
R1874t trips breaker
See my help file on door switches here.
The relevant service manuals are here and here.
If needed, you can order Sharp parts from Encompass here.
Apr 13, 2013 | Sharp R-1874 Convection/Microwave Oven
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
Sometimes, only sometimes, mhen we run the
your microwave is ok, your breaker is bad or is not strong enough for the microwave. microwaves need a dedicated 20amp breaker
Feb 04, 2010 | Emerson MW8107WA Microwave Oven
Tripped a breaker
sometime the kitchen has gfc outlets around the walls and one of them tripped. but not likely , it sounds like the microwave fried some valuable circuitry.
May 12, 2008 | Goldstar MV-1501 Microwave Oven
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
