Question about Dishwashers
Error code E8 on samsung DMS300PR,what does it mean
Does any one know what E8 error code stand for on a Samsung DMS300PR dishwasher
SOURCE: smeg code E8
I have exactly same problem. Have you solved it yet..
Posted on Aug 30, 2008
  • 234 Answers
SOURCE: SE error code on Samsung dishwasher
Here are the error codes from Samsung's website:
Error Codes spacer.gif If your dishwasher is displaying an error code, please refer to your users manual for an explanation. If you don't have your users manual on hand, you can download it from Samsung's Download Center. To go to the Download Center and download the users manual for your dish washer, click here.
Common error codes caused by installation errors are:
  • 5E which indicates a kinked or bent drain hose
  • 4E which indicates that the water supply valve is closed or not fully open
  • LE which indicates a leak.
I hope that this helps!
Posted on Apr 15, 2009
  • 8 Answers
SOURCE: samsung dishwasher PE error
Needs a new Main PCB board. I have changed two same error code
Posted on May 06, 2010
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
SOURCE: My Samsung dishwasher has a
Most common error codes that are caused by installation errors are:
  • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
    • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
    • Water filtration info.
Posted on Jan 21, 2011
What Samsung refrigerator rsg5furs error fault code e8 mean??? What can I do?
try and reset it maybe power went out fer a sec and throwed off the computer thingy?
Dec 23, 2016 | Samsung Refrigerators
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
Why is my machine not spinning
Well, it would help to know the make and model... on a Samsung the E8 code means the water hoses are connected to the wrong taps (i.e. the hot hose is hooked to the cold tap and vice-versa).
If it's not a Samsung, please provide more info.
Mar 08, 2015 | Washing Machines
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
