Question about Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
RT 7690 2
How do I take it apart and reassemble? The laser will power up for about 30 seconds i believe its dirty
Laser level problem
I had the same issue. The laser would only turn on intermittently and mostly not turn on at all. Since the green led would come on for 2 seconds when you first turn the rotary laser unit on (as per the user manual) I decided that the problem was probably with the remote. I took it apart (4 screws) and cleaned the corrosion off of the battery contacts on the slider switch and the two plates that the switch sliders make contact with. I also bent the two thin slider contacts so that they would contact the corresponding plates on the circuit board with a little more pressure. Put it back together and that seemed to fix it.
Feb 19, 2014 | Robotoolz RT-7210-1G Robolaser,...
The laser will not light up. i've replaced the batteries
First, be sure to clean the battery connection points with an electrical contact cleaner and be sure that the batteries are new, not just different. If that does not work, try placing the instrument in a freezer for at least 30 minutes. This worked with my 5 point Stanley Fat Max. The freezer will cause some condensation to form on the inside of the instrument, but why it makes the diode work is a mystery, at least to me.
Sep 13, 2011 | Robotoolz RT-7210-1G Robolaser,...
RF Remote for RT-7690-2 Unit will not respond to either the horizontal or verical Buttons and keeps beeping and the arrow flashing in the horizontal mode.
I've never come across that with mine, but I have a couple thoughts that you might try ........
First, check and make sure there are no buttons stuck down. And the second thing is take the battery out for a minute or so and see if it clears it. In fact, you might also want to check the battery voltage. I suppose there's a chance that low voltage could do that??
Hope one of those helps!
Ed
Jul 23, 2011 | Robotoolz Laser Detector/Receiver
My dvd player won't read my dvds. it attempts for about 30-60 seconds and then reads "no disk"
The laser is either dirty, or out of alignment or possibly too weak to read the disc. Try one of the laser cleaning disck with an alignment check I believe that maxell sells these, if you can't find one then a repair technician can adjust or clean i, but if the laser is no good then it will need replaced. Might be better to replace the unit before having a tech work on it or your costs will exceed a new unit.
May 19, 2011 | Craig Televison & Video
Kx-td7690 will not register with taw848 \r\n kx-td7684 works fine with taw848
if you are able to register the 7684 with a 0151 cell station, but not the 7690 then that will lead me to believe that the 7690 is acting defective
Jan 06, 2011 | Panasonic KX-TD7690 Cordless Phone
Hi I need a manual for porter cable robotoolz RT-7690-2 blaser level . Thank you.
You can get the manual on the link below please give it time to download. It is a large file.
http://www.ferramentaonline.com/shop/az/futtura/RT-7690-2%20series%20user%20guide.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 01, 2010 | Garden
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level Logo
67 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
