Question about Keurig Platinum B70 Coffee Maker
Keurig not ready
I have a Keurig B70 and it says not ready. It will not let me do anything - I have unplugged it and plugged it back in and it says not ready? Is there anything to do to fix it?
  • 1,511 Answers
The handel is not in position. Press firmly and make a positive connection.
Posted on Jan 30, 2014
  • 16 Answers
SOURCE: Stuck in Not Ready mode Keurig b70
1.) Check if the sensor within your coffee maker is clean... Clean the unit before you use it...
2.) Restart the unit by turning it off... Pulling the plug from the power outlet...
3.) If problem still persist... Have it be check for warranty purposes...
Posted on Oct 09, 2010
  • 28 Answers
SOURCE: My Keurig B60 just stays flashing
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
  • 5370 Answers
SOURCE: My 2-year old Keurig Platinum
Click this link directly to disassemble the unit and also see the internal parts diagram:--- http://technoanswers.blogspot.com/2011/02/how-to-disassemble-keurig-platinum-b70.html ------------ keep updated. Thanks.Helpmech.
Posted on Feb 08, 2011
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Says not ready
Handel is not in position properly. Press down well and it will work.
Apr 27, 2013 | Keurig Platinum B70 Coffee Maker
Power switch doesn't work.
The handle is not making full contact and it will not signal the next phase to start.
Jan 28, 2013 | Keurig B70 Coffee Maker
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
The display keeps flashing Not Ready. Water is full. I've unplugged the machine and plugged it back in. Why won't it get ready?
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
May 29, 2011 | Keurig B70 Coffee Maker
New Keurig B70 (brewed about 20 cups of coffee) won't brew even when it indicates it's ready. We were able to start it after multiple attempts - removing k-cup, unplugging, turning it off, etc. Does it...
I had the same problem. I called Keurig. After much back and forth of "do this" "OK, I did that. It still doesn't work" they are going to send me a new brewer in "5-7 days". I just have to send back the K-cup assembly.
Jan 07, 2011 | Keurig B70 Coffee Maker
Machine shuts off and says NOT READY. It will not work again until it is unplugged for a minute. Plug it back in, water heats and READY. It is not set to shut off. It shuts off soon after using for no...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dad
asd
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
838 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
