Diagram philips tv 29pt5026/79
I need a diagram of the power supply for transistor position 7521
buBruce
  • 14 Answers
SOURCE: repeated burn up horizontal transistor
Yah get out of old technology.
Posted on May 31, 2008
  • 158 Answers
SOURCE: Need cct diagram or can
May have psu for this model please let me know no`s.on psu board.before it went completely did you have sound but no picture?
may be able to suggest solution if this is the case.SUPER8.
Posted on Aug 01, 2008
SOURCE: berndulay@yahoo.com
sony kv-1982m7 tv. power supply problem. the b+ is ok and the supply is ok the power supply transformer is not isulate that why the tv is not work or on
Posted on Oct 15, 2008
daniel719
  • 240 Answers
SOURCE: Sony TV KV-32v15 Dead Power Supply
you should of recived a 0.01ohm resistor it is wite and sayes sony on it.
its a flame proof resistor that needs to be the very same
look for it on the pcb test it its probly open right.
ask them to send you the right part.
regards,
daniel.
Posted on Jan 11, 2009
daniel719
  • 240 Answers
SOURCE: transistor lost.
if you are replacing 7402
also replace diode 6404 this diode even thou it test goo will in long term overheat 7404 and caus it to go bad by leakage.
and if 7402 gose bad it is regulating the 15v stanby volts that is 7412 is also going to be bad so replace 7412 also
now
the part numbers are:
7402 = # 932211676682
7412 =# 932210514682
thanks,
daniel.
Posted on Jan 13, 2009
Diagram for psu transistor position 7521
Download the repair manual to this set by internet. It has all details.
Apr 27, 2013 | Televison & Video
I want to know the value of transistors. my Philips TV 25PT4473/69T power supply is blown up. If Circuit diagram could I get
You have to try in Google search.
If the transistor body is not damaged, you can read the type no. Replace it with identical No. Make sure the diodes and capacitors are not damaged. Check with multi- meter
Sep 29, 2010 | Philips Televison & Video
TV went out.
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 02, 2010 | Philips Magnavox 42MF521D/37 Television
A scheme of philips 63kv5616
Hello, just got your note, till today I fhave found a diagram of that TV - it's g110 chassis, in some days I'm gonna to try and repair it. If there's a trouble then I let you know and ask for a support. Thank You. Witesmol
May 07, 2009 | Philips Televison & Video
Transistor lost.
now
thanks,
daniel.
Jan 13, 2009 | Philips 19PR19 19" TV
I need the electrical diagrams to repair my rear projector model 55PW9383/17F Chassis DPTV340. Failure: no power on
You prob do not need a diagram to figure out this problem. If it powers on, then powers right back off again, then you could have a serious horizontal transistor short. If the TV is just dead period, you can try to replace all the large capacitors around the power supply area. A bulging top or leaking around the bottom are nice features to identify problem caps.
Nov 14, 2008 | Philips Televison & Video
PHILIPS TV 32PT6441/37 SHUT DOWN
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Philips 32PT6441/37 32" TV
Tv philips 28"
Hello, you (tech) can try this remedy - 1500 = fuse (250V/4A) - 3523 = resistor (47R) - 3527 = resistor (0.22R) - 3532 = resistor (2.2K) - 6500 = diode GBU4JL7002 - 6523 = diode 1N4148 - 7520 = circuit TEA1507P/N1 - 7522 = transistor BC847B - 7521 = transistor STP10NK80ZFP - 6526 = diode BZX384-C22 - 7515 = optocoupler TCET1104-G - 3526 = resistor (0.15R). - 3526 = resistor (0.22R). If you need more info please advice. Arpi
Jun 17, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
