Question about Acer Aspire Computers & Internet
System Restore Disk won't work
When I turn on my laptop this comes up: For Atheros PCIE Ethernet Controller v2.0.1.9(12/15/09) Check Cable Connection! PXE-M0F : Exiting Intel PXE ROM. Operating System not found. I have tired using the System recovery disk it'll load what language i want, then it'll go to the options menu but won't let me chose any other option but exit. what do I do?
  • 42 Answers
Disconnect your ethernet cable. Try restarting with last good know confirguration. Turn computer on while tapping F8 key. There are options there. You may also see Repair my computer, I would definitely do that. If this does not work then your computer's boot order is messed up, you can fix it. It is possible you may have to reinstall your operating system from your recovery disk. First things first.
Posted on Apr 27, 2013
  • Vicky Apr 27, 2013
    I just want to add that your CD/DVD Rom may be bad. Just fixed one with similar symptoms.
    New Friend:
The Recovery disk could be damaged or corrupted. The reason you are getting the Ethernet controller error your laptop can not find an operating system on the drive. With the aspire try ALT-F10 when you power on the system it will take you to a system restore partition. This will only work if the Hard drive is working. And it will wipe your drive so if you did not have any backups well you will lose all data on the disk.
  • 142 Answers
SOURCE: My gateway 2118u netbook will
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Posted on Sep 09, 2010
ratonxi
  • 112 Answers
SOURCE: intel UNDI, PXE-2.0 (build 083) Copyright
That message is because the laptop is trying to boot through the network. You have to change the boot order in the BIOS, and put on first place the hard drive. Press the F2 key just before turning on the laptop. You should go to the bios program. On the bios, search for the Boot tab-move with the directional keys- you should see something like this: http://slackworld.berlios.de/2007/images_vmware/vm-bios-cdrom-boot.png. Press F5/F6 to move the hard drive on top. Then press F10 key, hit "Y" and then "enter". The laptop will reboot and it should boot through the hard drive-on which you have windows. If with hard drive on top, you still get that messsage, you will have to reinstall windows-it means that the files in the hard drive are corrupted- or replace the hard drive.
Posted on Jan 03, 2011
  • 451 Answers
SOURCE: Dell Inspiron 14R Laptop. Daughter spilled
Ya sounds like the hard drive has died or there is a interface problem since you suffered from water damage. you may be able to get data off the hard drive by using a external hard drive connector but it may or may not work.
Posted on Mar 20, 2011
Testimonial: "Ok thanks, i got a better idea and understanding about whats going on."
DHINCE10
  • 169 Answers
SOURCE: When I turn on my laptop it goes to a black
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
Posted on May 10, 2011
  • 731 Answers
Sounds like your hard drive has gone bad or your OS have gotten corrupted as it's trying to boot from a network connection.
If you have a bootable CD or floppy you can try at the command prompt
chkdsk c: /f if that doesn't work try
fixmbr
If neither of these help try reloading your OS but honestly it sounds like a defunct hard drive
Posted on Jun 01, 2011
Toshiba satellite pxe-m0f
I would check the hdd is OK and not full of errors. When you press F8 just before boot can you select restore? If you can the restore partition is OK and it will restore itself to factory condition. If you can't, re run your restore discs or use an OS disc and install drivers when you get online.
Mar 19, 2014 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
No bootable device packard bell-what do i do?
check your bios settings and make sure your hard drive is first in the boot order.
Nov 24, 2012 | Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Why won't my laptop load windows 7 when turned on? All I get is a black screen with acer on it.
Need to have the hard disk checked. The computer is not finding the operating software to run. This is found on the hard drive. Hard drive is bad.
Nov 10, 2017 | Acer Computers & Internet
How do i fix my laptop if it don't start and it says intel UNDI , PXE-2.1 (build 082) copyright (c) 1997-2000 intel corporation for atheros PCIE ethernet controller v2.0.0.4(03/03/09) client mac...
Your laptop can't find an operating system, check the operating system as it installed properly. If its is then you need to check the hard disk drive of your laptop because it is missing from the motherboard.
Jul 21, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When i turn the power on on start up it goes to a black screen and says intel UNDI, PXE-2.1 (build 082) copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
You get this kind of message when the laptop could not identify that there is a hard disk drive installed inside the laptop. Check your hard drive & make sure it is not dead.
Jan 07, 2011 | Acer Aspire One PC Notebook
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
