It is just a standard Small Edison Screw (SES) appliance bulb. There is normally a removable cover on the exterior of the cabinet right behind where you can see the bulb on the inside. Remove the cover, unscrew the old bulb, install the new, replace the cover.
You can change the bulb from under the bonnet there should be a black rubber cover on the back of the light were the wires connect to the light bulb unplug light pull rubber cover remove metal clip then change bulb.
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)Remove the louver by removing the three Hood Louver Screws.
3)Push in the upper tabs and pull the louver away from your appliance.
4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
If you are trying to change the light bulbs underneath your Microwave:
1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
2)To open Light Cover, remove the screw on the light cover.
3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
4)Close the Light Cover and secure with screw removed at step 2.
If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
·Close light cover and secure with screw removed in step 2.
I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Unplug the Whirlpool refrigerator from the electrical outlet. Step 2 Locate the bulb on the inside of the Whirlpool refrigerator. Step 3 Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required). Step 4 Unscrew the old light bulb. Step 5 Screw in the new light bulb. Step 6 Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb. Also note that the below can also work
Unplug refrigerator or disconnect power. Slide the light bulb cover toward the back of the compartment to release it from the light assembly. Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts. Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover. Plug in refrigerator or reconnect power. To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly. The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts. Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly. Plug in refrigerator or reconnect power.
Replacing Light Bulbs To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power. To avoid personal injury or property damage, observe the following: • Allow light bulb to cool. • Wear gloves when replacing light bulb. Fresh Food Section (style of light shield varies) 1. Slide clear light shield toward back of compartment to release from light assembly. 2. Remove light bulbs. 3. Replace with appliance bulbs no greater than 40 watts. 4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield. Freezer (style of light shield varies) 1. Reach behind the light cover. 2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back. 3. Remove the cover. 4. Remove light bulb 5. Replace bulb with appliance bulb no greater than 40 watts. 6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
