Question about Dryers
Prima dishwasher lpr601
Fuse blowing mid cycle
2 Suggested Answers
  • 239 Answers
SOURCE: Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Posted on Mar 02, 2012
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Frigidaire fdr251rjs
The cycle timer could have failed
Oct 11, 2013 | Frigidaire Dishwashers
The dishwasher stopped in the middle of a cycle and now it will not turn back on. None of the buttons work, no lights are on and yes, it does have power.
The thing that very likely caused your dishwasher toquit mid cycle is a blow fuse that clipsonto the control board. It is a fairly common occurence...in fact common enough i have wrote this tip about it so i would not have to write the same thing over and over. here is that tip.
http://www1.fixya.com/support/r10341846-will
GENE
Sep 28, 2011 | Whirlpool Gold GU2275XTV Builtin...
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Dec 05, 2007 | Dishwashers
The fuse in the plug keeps blowing. Initially it would run for a while - sometimes 3 or 4 cycles - before blowing. It now blows the fuse the second that I plug in to the socket, even with the on/off button...
Lower the outlet hose into a washing up bowl, it should then Drain. Check the heater to see if it is earthing you get to it by removing the right hand side panel.
Nov 28, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Aug 15, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dryers Logo
21 people viewed this question
Top Dryers Experts
