Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
I have a aqua flow xp2 model no. 06115070-1 that the motor appears to have gone. can just the motor be replace or do i have to buy yht whole pump
5 Suggested Answers
  • 366 Answers
SOURCE: i am trying to find a replacement for ann XP2
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
Posted on Dec 02, 2009
  • 990 Answers
SOURCE: Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Posted on Apr 16, 2010
adamh294
  • 310 Answers
SOURCE: I was told that the Aqua Flo Master Xp2 Spa pump
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Posted on Jan 13, 2011
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
aquaman987
  • 927 Answers
SOURCE: i have an aqua flow
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Posted on Aug 02, 2011
Flow master XP2 by aquaflo for spa; it clicks, but does not start. I could turn the shaft with a wrench, all plugs work.
the start switch has trash in it , use compressed air and blow out the back of the motor, this works most of the time for me. otherwise the motor will need to be dissembled and can be tricky do to easy to break parts. search your area for your local pool pump motor repair guy with free testing. and ahve him clean the switch
Sep 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Parts. i have a 408 seaspray model and the seal kit is bad. I need a replacement, but am having difficulty finding one. Does Coleman have the part for sale?
The XP2 pump uses a 5/8" shaft seal.
You can find them as under part numbers - PS-200, AS-200 or 92500150.
Feb 27, 2012 | Pool & Spa
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I need to purchase a stationery switch for a flowmaster xp2 model 06620390-2
What is the serial number that goes with the motor model number? I am assuming the 06-620390-2 is off the motor; if not please also add the motor brand and model number as well.
John
(P.S. for a faster response please send this information thru our website at www.arrowmotor.net using the contact feature)
Dec 27, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
What windings do the leads of the capasitors get attached to for the flow master xp2
Please reply with the motor brand, model and serial number so we can get you an accurate wiring diagram. Simply comment on this post and enter the information there.
John
Dec 09, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Where cani find replacement thru-bolts for an Aqua Flo XP2 pump?
A local motor repair shop would have the thru bolts. If you have at least one good one, you could match up the size, and cut soem threaded rod. Most motors this size use either 8-32,10-24,or 10-32 bolts. You can buy threaded rod at hardware store. Try to find galvanized, to prevent corrosion, or paint the part inside the motor if you cannot.
Aug 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am trying to find a replacement for ann XP2
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
29 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
