Question about Pentair Whisperflo 3/4 Hp 115/230v
Pool motor factory wired for 230v.need to change to 115v
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Take off back panel of motor if a switch turn to 115 volts or 120 volts what ever choice they give you if no switch see side of motor it will show you on low voltage to move the brown and white wires
Posted on Sep 07, 2014
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: my motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Posted on Jun 15, 2009
Changing a pool pump motor from 230v to 115v
of motor for schematic on 120 volt vs 240 volt wiring
Jan 26, 2014 | Century Pool & Spa
I have a AO smith ST1152 and red black and green wires. How do I wire it
Verify the voltage to the pump. These days motors and pumps largely are set to run on 230v out of the box (for in ground pools). If your supply voltage is 115v, the motor will run at half speed. This would cause poor suction. If this is the case, do this:
On the side of the motor there is a diagram on how to convert the wiring from 230v to 115v so it will run on the correct voltage. Most of the time, that's the issue. Flip the breaker off before working on it.
Nov 30, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
1 1 2 hp pool pump wire
look on side of motor there is a schematic for low and high voltage high voltage from factory
Apr 28, 2013 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
I just bought a AOSmith 1hp pool pump. I do not
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Jul 05, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My motor is wired for 230v and I need it to be 115v
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Pentair Whisperflo 3/4 Hp 115/230v Logo
130 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
