EUROLIVE B212D The high is not working
  • Audio Player... Master
  • 16,162 Answers
Check the speaker and cross over with a meter and a scope.
Posted on May 13, 2013
Accidentally plugged my b212d in wrong voltage,now when put it on its makes a tiny cleeking sound and the power light dosnt come on.what should i do
Unplug the unit and replace the fuse. Same wattage and type as the one you remove.
If you've already done this, then you've destroyed other components inside.
Aug 04, 2016 | Behringer EUROLIVE B212D Active 550-Watt...
Where can I dowload the user manual
Here is the link to that manual.
http://www.behringer.com/EN/Products/B212D.aspx
Jan 02, 2015 | Behringer Eurolive B212A Speaker
Why does the fuse keep blowing?
Hmmmmm. Are we talking about your internal or external fuses; Do they blow at the moment you put power on it, and what about the switch of the used voltage ?.... And was it straight away , since when you bought them; Then just send them back, Second hand?, too bad, you're ripped off .
Jul 21, 2014 | Behringer Eurolive B212d-wh Active...
My speaker is shutting off randomly when hooked up to a mic
This problem has happened to others. If you purchased it new, Behringer will repair or replace it.
Feb 20, 2014 | Behringer EUROLIVE B212D Active PA Speaker...
I have a behringer eurolive b212d no power no lights on when I push the button I hear a clike in the speaker but no power. tested the fuse its ok. could there be a fuse inside the power unit .any help...
Eurolive Active speakers from Behringer suffers of bad power supply/Amp design, if you open up the back of your speaker you will probably find that the AC connector has a burnt or loose connection as well as a black spot, if not, check the power supply/power amp coils for cracked connections, let me know for improve help.
Sep 20, 2013 | Behringer B212D Powered Speaker (550...
Why did my Behringer b212d horn stop working.
The problem is bad high freq. IC TDA7293.
There is no pasive crossover.
Nov 30, 2012 | Behringer B212D Powered Speaker (550...
Behringer b212d hums loudly
If it's only on one side, then you may have a defective cable within the system. That would be my first guess. If both sides hum, then an improper ground could be the culprit.
Oct 08, 2012 | Behringer EUROLIVE B212D Active 550-Watt...
12" woofer not working
I bought a 3rd B212D unit that powers on, has white noise, no music. I took the 8 screws off and discovered that the solder connection at the woofer had broken off. I surmise that either the unit was dropped or the speaker wire had gotten hot over the years. Since the amp had an open output from the break, the high output burned up as I heard a pop when I turned the volume up. . If your volume wasn't maxed out, you could check the wiring and make sure it is connected & save yourself some change!!!
Jun 22, 2012 | Behringer B212D Powered Speaker (550...
27 people viewed this question
 Grubhead
Grubhead
