Question about Samsung 3.9 cu. ft. VRTTM Steam and PowerFoam Front Load Washer
Samsung vert leaking from bottom and side
Leaking from bottom and side
  • 97 Answers
SOURCE: RS253BAWW Samsung Side fridge water leak
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Actually a pretty common concern... second time in two hours I've seen it. :D
Posted on Jul 29, 2009
  • 13 Answers
SOURCE: Water in the bottom of the frig, right side.
Find the condensate drain in the bottom of the frig and clear it
Posted on Jun 01, 2010
  • 51 Answers
SOURCE: I have a Samsung Refrigerator
read this. it might be of help http://techie-doc.blogspot.com/2010/09/fixing-refrigerator-problem-frosting-in.html
Posted on Sep 16, 2010
  • 884 Answers
SOURCE: Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
Posted on May 20, 2012
richroth
  • 9472 Answers
SOURCE: My Samsung RS2630SH is leaking water from the bottom on the freezer side and there is ice in the bottom of the freezer.
You will need to check the drain line in the back of the freezer for blockage.
Posted on Dec 10, 2012
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
May 20, 2012 | Samsung Refrigerators
Jun 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung frig is leaking water at the bottom - it does not appear to be leaking from the inside because it is dry, but from somewhere internally at the bottom. What would cause this? The temperature...
SMALL PLASTIC water pipe under front of door has joiner which changes from 8mm ? TO 10MM ? this leaked on mine and had to be replaced .any good plumbing supply shop could supply. May need to be tightned.
May 05, 2010 | Samsung RS2630AWW Side by Side...
The screen bounces with lines
you probably have a capacitor either in the vert driver or vert output circuit leaking
Aug 28, 2009 | Mitsubishi Televison & Video
Water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
Aug 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
WATER LEAK FROM BOTTOM
the ice maker is a common fault on those appliances expensive to replace but quite easly done with regard to the leak eithr the drainage tray is blocked or one of the water feed hose is disconnected or leaking call an engineer
Nov 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Samsung 3.9 cu. ft. VRTTM Steam and PowerFoam Front Load Washer Logo
20 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
