Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Is The DVI-D Port HDCP Compilable
I plug my ps3 in through HDMI-DVI converter cable but just get a blank screen, been told that my tv is HD compatible at 720p but im really not sure, looked all over internet for a solution but unfortunately can't find anything would be alot of help :)
    Top Expert:
  • Panasonic Master
  • 74,243 Answers
No. They are not compactable.
Posted on Apr 27, 2013
welcomejee
  • 10594 Answers
SOURCE: Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
Posted on Nov 28, 2008
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
tvservice306
  • 458 Answers
SOURCE: HDMI connections no longer work after lightening storm. TV works
try replaced H board
Posted on Aug 13, 2009
  • 1623 Answers
SOURCE: Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Posted on Oct 28, 2009
  • 8 Answers
SOURCE: Closed-captioning doesn't work, either by pressing
Yes...
My TV is like that too!
Posted on Dec 23, 2009
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Hooking up ps3
To get 1080i (the 50V will not do 1080P) from the Blu ray player you do have to use HDMI output on the PS3 to the DVI input.
I found one at Walmart. Phillips makes an HDMI to DVI plug also at Wmart.
The PS3 must be set for the output you want on your TV.
Look in your manual in the PS3 box or go to http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The web site has much more detailed instructions, but the basic answer to your question is below.
  • The cable required to output a particular video mode may not be included with the product and additional purchases may be necessary. For details, refer to the documentation supplied with your system.
  • If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
  • Copyright-protected Blu-ray video discs can only output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP standard.
  • Hope that helps!
    Merry Christmas and Happy Holidays to you and your family.
    Dec 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
    Blank Screen using HDMI-DVI cable for PS3
    Sounds like your LCD monitor isnt HD compatible.
    Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
    Compatibility ps3 lg rz32lz50 tv
    Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
    Sep 06, 2008 | LG RZ32LZ50 32 in. LCD Television
    HDMI/DVI CABLE CONVERTER
    In my opinion, you should be fine with getting just component cables.
    There is a difference, but it's not a very big difference.
    Jul 23, 2008 | Sony Playstation 3 (PS3) Console
    Dell w3000 & PS3
    This may not be DVI issue.
    I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
    Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
    Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
    Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
    Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
    53 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
