Question about Microwave Ovens
Whirlpool gh7155xhs troubleshoot
They keypad doesn't seem to be working
  • Microwave Ovens Master
  • 9,047 Answers
Unless there is moisture or grease on the control circuit board, it's likely failing membrane keypad.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
For model GH7155XHS0, the exploded view and parts list are here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20885939.pdf
The part number is 8171854 "Controller Sub Asy".
For model GH7155XHS1, the exploded view and parts list are here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208183934.pdf
The part number is 8183977 "Controller Sub Asy"
You can order the parts from the Pros here.
Some connectors may have a lock.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Posted on May 04, 2013
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
It is making different kind of noise and won't generate heat.
Most often with MW's the Magnetron fails that as well as the high Voltage Diode. MW's are NOT to be trifled with they are lethal to service and MUST be done by an experienced professional.
The best thing to do is contact Whirlpool, and ask for a referral to an authorised service center, make contact here and when face to face first only ask for a "Quote" as to costings and go from there.
Sep 10, 2011 | Whirlpool GH7155XHS Microwave Oven
My microwave seems to have overheated and is not shut off. breaker is okay, outlet works
Well Certain models of Whirlpool microwave ovens have a problem with their thermal fuse that causes them to overheat. Whirlpool has a service bulletin out on this problem.
CORRECTION: Install a thermal cut-off repair kit (Part #8205204) to
repair the wire and terminals. Once this is done, a new
rework kit (Part #8184461) must be installed.
Good Luck!!
Thanks
Dec 28, 2009 | Whirlpool GH7155XHS Microwave Oven
Even though timer starts the microwave doesn't start cooking
read this post
Parts:
magnetron: W10131681
HV capacitor: 815124
HV diode: W10201950
HV transformer: 8171873
Of note: generic parts are cheaper and will work as well.
Oct 20, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Door won't open
Sounds like the electronic actuator for the door lock has failed check for current at the actuator and if this seems ok then replace the actuator if not then replace the circuit board.
Jan 22, 2009 | Whirlpool GH7155XHS Microwave Oven
Buttons #3 & 8 on control panel not working
Sounds like your keypad has failed and you need the fan circuit repaired on the control panel.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Add to that about $75 for the keypad.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | Whirlpool GH7155XHS Microwave Oven
The microwave does not work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
Microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Dec 20, 2007 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
