Question about Bosch Washing Machines
My bosch woh 3010 does'n't evacuate water anymore. how can i fix that?
I have a bosch 7801 dishwasher that is 12 years old and is not heating the water? I presume that this is the heating element so is it worth fixing or should I buy a new one?
The new ones don't have a heating element. They tell me the US government doesn't allow them anymore because it's not "energy efficient". My 20-year old Kenmore washed better than my one-month old Bosch. Fix it if you can!
Jan 04, 2016 | Bosch Dishwashers
How do i fix my diswasher if the water stay in?
The evacuation pump is clogged or has failed all together.
Oct 24, 2014 | Bosch SHU3036UC Dishwasher
How can I repair my washing machine ? Evacuation system is not working anymore ?
If the motor is running the pump is either clogged or bad. Remove the hoses going to and from the pump and inspect them and the pump intake/impeller for any obstructions. If clean the pump could be bad or the drive belt could be brokeen.
Aug 11, 2014 | Kenwood Washing Machine Mini 1050, White
Machine won't start the wash cycle
All bosch appliances are sold with a two year manufacturers guarantee. Call 0844 872 8999 to arrange an engineer. Sounds like it could be any of the following Heater, PCB, Pressure switch or Motor fault
Mar 24, 2013 | Bosch Washing Machines
I have a Bosch 21e instantaneous water heater attached to a Hills evacuated tube system. On cloudy winter days when we use the washing machine on warm the heater has an intermittent fault for a couple of...
Wild guess, but washing machine use solenoid valves that turn on and off instantly, causing a great deal of hammering of the entire water system.
Regardless of whether or not this fixes your current problem, you really should install a large air canister to buffer the shock in the system. Normally I would suggest installing in the cold line just after it enters the house, but with your solar heating system, you need one after it as well, because there is quite a bit if switching going on. It is quite possible the switching is the problem and not the Bosch heater. Try bypassing the Hills system and see if that helps?
May 16, 2011 | Water Heaters
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Hello, My Bosch she44c dishwasher is not evacuating the water from the machine. I checked the line and i can hear the motor trying to pump. I've tried to make sure the impeller was clean, so at this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Spin cycle will not work on washing machine
The most likely cause is the drain pump is not allowing water to evacuate properly. Clean out the pump filter and try it. If all of the water is gone and the machine is empty .....see if it will spin then if not then the motor carbon brushes may need to be repalced.You will need technical assistance for this.Good luck
Aug 01, 2010 | Bosch Washing Machines
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
Washing Machines Logo
124 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
