Question about Smeg DWI614 Built-in Dishwasher
HOW DO I CHANGE THE HEATING ELEMENT?
THE HEATING ELEMENT ON MY SMEG INTEGRATED DISHWASHER HAS GONE AND I NEED TO REPLACE IT HOW DO I DO THIS?
5 Suggested Answers
  • 258 Answers
SOURCE: Smeg dishwasher tripping out fuseboard
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Posted on Jan 18, 2009
Testimonial: "Sorry it has taken so long to get back to you......forgot the log in details and sorted it in the meantime. Thanks for replying though. :)"
  • 120 Answers
SOURCE: Smeg integrated dishwasher continually washing -
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Posted on Nov 03, 2009
ginko
  • 19396 Answers
SOURCE: I have an E3 error
Hi.
E3 means that there is a problem with the heating system. The problem is either heating element or thermostat. The heating element in SMEG dishwashers is usually located underneath the appliance (in some model is at one side or at the back). Access is gained removing the front inspection panel at the bottom and the right hand side panel. Check at the bottom and see if the heating element is there. Check near to the heating element and locate also the thermostat, connected in line with the heating element. If the thermostat is not at the bottom, then it is inside the door, clipped near to the dispenser.
Before replacing parts test both heating element and thermostat.
Both parts are tested reading Ohms. Set the Multimeter on Impedance (any R scale).
Remove thermostat and element from circuit and read impedance touching each part contacts with multimeter probes. If the element reads infinity of Ohms (open, same as on air), then the part must be replaced. A good element will read a value different from infinity (SMEG is usually 30/40 Ohms).
The thermostat is tested in a similar way. A good thermostat will read zero or a couple of Ohms at room and will open when water is hot. Usually is only necessary to test the thermostat at room, testing in hot water is more complex. If the thermostat is open at room temperature, replace the thermostat (at room it must read zero or a couple of Ohms). If the thermostat does not open in hot water, replace the thermostat.
If thermostat and element are OK, inspect the control board.
Regards.
Ginko.
Posted on May 03, 2011
michael_p_pi
  • 112 Answers
SOURCE: how do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Posted on Sep 02, 2012
Replace heating element in smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 02, 2013 | Smeg Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
Nov 29, 2011 | Smeg Ovens
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Feb 13, 2011 | Smeg Ovens
Not heating up so not cleaning dishes
heatman101
Jul 30, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg integrated dishwasher continually washing - won't move to drying cycle.
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Smeg oven ss336-5 not heating
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg DWI614 Built-in Dishwasher Logo
49 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
