Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
Hard starting with air filter in place.Starts when air filter is removed.
Light scoring (vertical lines) on piston viewd by removing muffler. Tried cleaning element. local dealer advises element is ok
  • Poulan Master
  • 7,482 Answers
Hi sdbrav
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 28, 2013
Testimonial: "Thanks Bud. Have already replaced/cleaned air filter, fuel filter/ fule lines and cleaned spark arester and muffler. Gas tank is clean. Used "Mechanic In a Bottle" too try and clean fuel system. Using 40-1 oil/fuel mix. Will try carb rebuild/replace and let you know. My Poulan 33cc is a 1998--worn diaphrams good possibility. Once the saw starts --runs and idles good. Thanks very much for all the info and suggestions--very helpful---I rate you AOK--Outstanding. Thank you. Sidney I have a new Walboro carb for a 025 Stilh that I am not using. Will check to see if they are interchangable."
4 Suggested Answers
  • 1584 Answers
SOURCE: how do i remove the piston shaft on a poulan wildthing
Take it to an engine reconditioner as its a specialised job, whether you are removing the conrod or gudgeon pin requires specialist.
Posted on Jan 26, 2010
  • 4088 Answers
SOURCE: poulan wild thing 18" Won't Start, Plug is wet
Check the air cleaner and muffler for plugging. Remove the carburetor, open the lower chamber and check the diaphragm for any holes or cracking. Also check the small fuel control valve that the diaphragm controls--either can cause flooding if not working properly. Hope this helps!
Posted on May 31, 2010
  • 2239 Answers
SOURCE: poulan 2150 saw will not start.
Many saws today have a alluminium key moulded into the flywheel, if the key has sheared the timing will be out and it will never start, remove the flywheel and check the key.
Posted on Jun 07, 2012
Stihl 024 AV won't start. Replaced carb, plug, air filter, fuel line. Ran fine for 10 min then quit.
Fuel mixed properly and fresh?
if you put a few drops of fuel directly into carb, does it run for a few seconds?
have you checked the piston for scoring? (By removing muffler)
Apr 22, 2017 | Stihl Garden
Very hard to pull start.
Two possibilities--one, the engine is flooded and the spark plug needs to be removed, then open the throttle and pull the engine through smartly several times to expel excess fuel. Check the air cleaner for plugging. Second, the engine may have been run without oil in the fuel which will result in the piston /ring(s) scoring itself and the cylinder wall severely. Remove the muffler and watch the piston as it travels the cylinder while pulling the engine through slowly. Any heavy scoring will necessitate replacement of the cylinder, piston, and ring(s)--an expensive process if you farm it out. Hope this helps!
Nov 09, 2010 | Garden
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
My weedeater leaf blower never gets up to its' old speed. Runs about 1/2 the power. Tried a new spark plug and air filter. New gas didn't help.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My husqvarna 225B leaf blower starts easy when cold and runs fine for about 5 min. then quits. Very hard to start after that.
A few possibilities, first check the tiny little vent hole in the gas cap for a clog.Second, check the fuel filter in the tank. Third, remove the muffler and inspect the piston for scores and that the rings are free, remove ant carbon build up from the exhaust port. If the trouble persists its time to go into the carb, The pump and metering diapgragms will harden over time and loose their elasticity and cause this problem also
Oct 29, 2009 | Husqvarna Garden
Wont start
Remove muffler and inspect piston, rings, and cylinder through the exhaust port. If any vertical scoring is visible you may need a top end rebuild, if not may be dirty fuel filter, cracked fuel line etc.
Apr 13, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a 125l trimmer and it runs for about 10 minutes and then it dies. it will restart, but will not run at trimming speed.
I had the same problem. Check the fuel line right above the grommet on the tank. Mine dry rotted and had a small hole in it sucking air. The trimmer would start ok but wouldn't run long or at all wide open. Replace the fuel line and grommet (all one piece).This fixed my problem.
Mar 31, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
My stihl FS51 needs adjusting/ repairing, is it worth it?
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. May have top end damage.
Mar 22, 2009 | Garden
Hard starting and when warms up rpm's drop
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Dec 21, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
83 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
