Question about Acer Computers & Internet
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
I type the right password, this laptop is brand new only 2 months old. Would really appreciate some help.
  • 42 Answers
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Posted on Apr 27, 2013
gink0
  • 35 Answers
SOURCE: User profile cannot be loaded
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
1s30
Posted on Jan 06, 2009
  • 7 Answers
SOURCE: CAN'T LOGON ....SAYING .....THE USER PROFILE SERVICE service failed the logon .user profile cannot be loaded ...never had problem before ...normally type in password and it loads ..
this may be a corrupted file for taht particular user thats causing the problem why cant you try opening the other user profiles or if you cant access that too then try turning on your pc and when the list of user profiles appear press ctrl+alt+delete key in and order but you should keep allthree keys down like how you would keep the shift button down while typing an upper case....now when you press all three down a small dialogue box will appear requesting username and password in the username box type administrator and click login no password required after it logs in create a new profile from the control panel but don't use this user profile again because if this gets corrupted then you would have to format your computer.....formating it will delete all the data stored on your pc.....
Posted on May 16, 2009
  • 1752 Answers
SOURCE: CAN'T LOGON....PLEASE HELP!
Use this to reset your password: http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
Posted on Oct 26, 2009
  • 857 Answers
SOURCE: I have an Acer Aspire 5532 Laptop with Windows 7
this problem happens when you try to lo-gin in a temp profile because of group policies.
Follow this step after loging in a admin account.
To resolve this issue, follow these steps:
  1. Delete the profile by using the Computer Properties dialog box. To do this, follow these steps:
    1. Click Start, right-click Computer, and then click Properties.
    2. Click Change settings.
    3. In the System Properties dialog box, click the Advanced tab.
    4. Under User Profiles, click Settings.
    5. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK.
  2. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type regedit in the Start search box, and then press ENTER.
  3. Locate and then expand the following registry subkey: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfieList
  4. Right-click the SID that you want to remove, and then click Delete.
  5. Log on to the computer and create a new profile.
This will fix your problem.
Posted on Mar 06, 2010
  • 278 Answers
SOURCE: unable to logon
hello!!you can solv your problem now from here
Posted on Nov 23, 2011
Won't log in, says "the User Profile Service service failed the logon. User Profile cannot be loaded."
This is a simple fix that can be done in a few minutes or less. It is a problem with either an update from MSFT that had gone awry or an attack from a virus... Anyhow the steps to take are relatively simple just follow along.
1 - go to this site and it will walk you through step by step
You receive The User Profile Service failed the logon error message *make sure to choose option 1
Apr 12, 2014 | Computers & Internet
Cant login
Restart your computer in safe mode. To do this first power it down wait 10 seconds. Locate the F8 key; press power button an start tapping F8 key. This will bring you to a screen with many options. Choose safe mode. This is a limited mode but many things can be fixed including your profile. Option 1. Go to control panel user accounts. Here you can add an account. Option 2 Delete your account (make sure there is another account you can log into prior to doing this) Go to start->computer right click then click properties. In system properties click advanced tab. Under user profiles click settings. In the User Profiles dialog box, select the profile that you want to delete, click Delete, and then click OK. Click Start, type regedit in the Search box, and then press ENTER. Locate and then click the following registry subkey:
    1. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
  1. Log on to the computer and create a new profile.
  2. Hope this info helps.
Apr 27, 2013 | Acer Computers & Internet
Hi there! I really hope you can help me! I have an Acer Aspire 5935G! Yesterday it was working with no problems! Today i turned it on & swiped my finger as i have it set to finger protected &...
This isn't a password login problem - the User Profile Service service failed the logon because it's corrupted. Try to login in Safe Mode and access your account from there . If you can then retrieve all your files while you still can and prepare yourself for a reinstall.
If you can't then you will have to use a Linux Live-Cd like
http://www.pclinuxos.com/?page_id=10
to recover your files before performing a full reinstall.
May 31, 2011 | Acer Computers & Internet
When i switch on the lenovo laptop y560 win 7 the user profile service service failed the logon user profile canot be loaded what to do how to solv the problem i can't login to laptop
try looking through this page
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
Its not written by me or anything but has all of the information that you need in order to sole your problem.
Hope this helps.
May 08, 2011 | Computers & Internet
My acer when I log on says user profile service failed the logon user profile cannot be loaded
use F8 and go into sfae mode, this will load a default profile and will allow you to add a new user (to create a new profile).
Then you can logon in using the new profile.
Apr 07, 2010 | Acer Aspire 6920-6621 Notebook
I have an Acer Aspire 5532 Laptop with Windows 7 Home premium. I wanted to logon to my Userprofile and it said: ''The User Profile Service service failed the logon. User profile cannot be loaded.'' What...
Mar 06, 2010 | Acer Computers & Internet
May 16, 2009 | Acer Aspire 5735 Notebook
Computers & Internet Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
