Question about Sharp (SHRAM900) All-In-One Laser Printer
Sharp AM-900 I have had this for about a couple of years. Now when I make a photocopy, there is a vertical straight line down the middle of the paper that comes out on all my photocopies. Any suggestions?
  • Cayetano Intriago Aug 07, 2007
    It is a straight fine line, not streaked, almost like someone traced a vertical line with a ruler. If I print from the computer or the glass it is fine. The problem is copying from the feeder slot.
  • robert315 Mar 27, 2008
    My cartridge dried up and the powdered ink got on a wheel or something because I have streak lines down the right side of the paper. I blow it out with an air hose, installed a new cartridge but the streak lines are still there. Also the lines aren't getting any lighter which you would think they should.
    Problem Solver:
  • 18 Answers
It is either in the path of the scanning like the platen glass or if it is a MFP check the little glass strip on top of the glass thats where auto doc feeder scan from, or the imaging drum/toner is bad, or the transfer belt is bad or worn and there could always be a roller causing the marks, or the fuser itself can be bad. there are just too many things that can cause that. is it streaks with no print or is it printed then scrated like streaks?
Posted on Aug 07, 2007
  • Alec Carpenter
    Alec Carpenter Aug 15, 2007
    the optics in the scanner for the auto document feeder is burned out. It can also be just that the optics need cleaning. When you put the paper in the feeder it goes through the machine and is scanned by a little strip of glass not the actual whole glass. it passes through a smaller scanner or just a scanner that stays still while the paper goes by it. If you are technical you can do it youreself but if not i suggest finding a technician and telling him of this problem. If you do feel like cleaning the optics it is just like cleaning a camera lens and you need to use something meant to clean platen glass. You can also use a can of air to clean out the optics of any dirt.
SOURCE:
Copy problems with xerox fx docuprint c3290
Hi you can have a few problems. 1: try cleaning the glass on the scanner. 2. If you have auto document feeder there may be paper or dirt on the lens that the paper passes over. Clean the long lens. 3 if you clean the glass and lens and still have the problem you will most likely need to have it serviced as there may be paper stuck in the drums that the paper passes through. Paper follows a different path when copied versus a straight print. Try to see what path the copy paper is taking and clean it as best as possible. Last trick is to take out toner cartridges and wipe them clean. Shake them forward to back and reinsert. You may have a worn out roller and if this is the case it is usually cheaper to just buy a new printer.
Nov 01, 2012 | Xerox Computers & Internet
I get vertical lines running down the middle of paper
lift the lid ull see a thin **** glass make sure its very very clean
Mar 30, 2010 | Sharp AL 1631 Copier
Hi weve just bought the tv ,its a LG ,its a clear pic but has a very fine vertical line down the middle ,its like a yellow line
Vertical IC is bad or capacitor 100uf 35v in front or behind vertical IC. Call Mats for Parts 1-800-628-1118 But to make sure is Line up and down or straight across TV?
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
Vertical lines slanted on photocopier
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Feb 17, 2009 | Ricoh Office Equipment & Supplies
Streaks on faxes and copies but not on printed documents
Clean the glasses on top!!! Your CORONA lens is dirty!!! it must have some cleaning brush or bar near the side!!!
Jan 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
There are white lines ony my photocopies
You need to be more specific with your diagnosis.
1- are they black or white lines?
2- does it happen when you put the paper in the feeder ( on top)?
3- what about if you put it directly on the glass?
4- do faxes come out OK?
Jan 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Trouble shooting
Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
Nov 12, 2007 | Office Equipment & Supplies
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Sharp (SHRAM900) All-In-One Laser Printer Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
